Mr.Phreak wrote:Although they're only useful if you pick temps that have decent visibility.....otherwise you're just posing
Correct, any temp lower than 6000k is best. Higher colour temp you go the bluer it becomes and the light output is less.
UTERUS wrote:Mr.Phreak wrote:Although they're only useful if you pick temps that have decent visibility.....otherwise you're just posing
Correct, any temp lower than 6000k is best. Higher colour temp you go the bluer it becomes and the light output in the spectrum you can see is less.
Mr.Phreak wrote:Bulb kits are.....Complete housing conversions aren't (as long as they comply with standards)
As per http://www.ltsa.govt.nz/vehicles/get-yo ... right.html
"High intensity discharge (HID) conversion kits
HID conversion kits (an HID bulb with a high voltage power unit or ‘ballast’ which fits into the original headlamp unit in place of the original bulb with no change to the headlamp lens, reflector or housing) are illegal on any vehicle being used on New Zealand roads.
However, a complete halogen headlamp unit can be replaced with a complete HID headlamp unit provided that the replacement headlamp unit complies with approved standards. If in doubt, get advice from a vehicle lighting retailer you trust."
barryogen wrote:when pricing up a full kit from Toyota for my corolla, it was ~$3k for the two front lights... approx $2k through revhead from memory... I still have "normal" lights.
B ROWDY wrote:Mr.Phreak wrote:Bulb kits are.....Complete housing conversions aren't (as long as they comply with standards)
Mr Phreak has it in a nutshell sunshine, if you know the brand then post it here and I can tell you if they comply or not, or if you want a list I can make one for you if thats easier??
Chur chur B~ROWDY
BlakJak wrote:Lighting rule info is in the FAQ section.
viewtopic.php?t=45506
Note:
3.2(4) The horizontal orientation of a headlamp on a vehicle must, when the vehicle’s front wheels are pointing in the straight-ahead position, ensure that the centre-line of the beam of light emitted from the lamp is projected either parallel to, or to the left of, the longitudinal centre-line of the vehicle.
3.2(6) A dipped-beam headlamp designed solely for a left-hand-drive motor vehicle, where the maximum intensity of the beam is dispersed to the right, must not be fitted to a vehicle.
12.1(1) A modification to a motor vehicle that affects the performance of its lighting equipment:
* (a) must not prevent the vehicle from complying with the applicable requirements of this rule; and
* (b) must be certified in accordance with Land Transport Rule: Vehicle Standards Compliance 2002.
The Vehicle Standards Compliance Rule 2002 goes on to state in some detail what requires certification...
If people have an opinion as to whether HIDs construe a 'modification' per the above, am interested...
Mr Revhead wrote:and if another wof guy see its and enters it in the wof syste, your screwed
2jayzgte wrote:TRD HID kit for the Jza 80 Supra legal or illegal???????
deaf_rattle wrote:Mr Revhead wrote:and if another wof guy see its and enters it in the wof syste, your screwed
i dont understand. i have never once seen the warrant people look up the car details before the warrant check has been done.
so what difference does it make if they enter it into the system?
Mr.Phreak wrote:2jayzgte wrote:TRD HID kit for the Jza 80 Supra legal or illegal???????
I would assume they meet the required standards, although I'd be waiting for to confirm. I think it'd probably be a grey area though, and I'm pretty sure they don't make em anymore
Users browsing this forum: Bing [Bot] and 18 guests
