Bolt-on racing pedal suggestions
Postby pjay » Fri Jul 13, 2007 5:48 pm
:o always try dry my shoes before i drive for that precise reason!!
pjay
Postby A.D.D. » Fri Jul 13, 2007 6:41 pm
gmacrae wrote:Only thing i'd say is you might want some more height on the gas pedal. Heel-toe is difficult on my corolla just because the gas pedal is a fair bit deeper than the brake, supra is perfect. You could cut a piece of 10mm thick *hard* foam the same shape as the gas pedal and stick it over the top. Try payless plastics or something.
I'll definitely give that a go. My accelerator is a bit deep.
As for the stick-on pedals, got to give them a miss. They really sound dangerous now
A.D.D.
Postby Dell'Orto » Fri Jul 13, 2007 7:04 pm
I had a set of Momo ones years ago, they were really good. Had to drill through the pedal itself to fit them, but made it easier to heel/toe as you can adjust the gap between acc and brake.
Probably unnecessary on many cars out there, but on some its useful.
Postby Zak » Fri Jul 13, 2007 8:52 pm
It much just be me, but I really like small pedals :oops:
I don't know why either.
All though I might try glueing sand paper to my little square pedals.
Zak
Postby frost » Sat Jul 14, 2007 12:55 am
go to your nearest skate shop and ask for some sticky grip sand paper stuff, i forgot what its called been so long since i had a skate board :oops:
that will be better then any sand paper and it can get wet and still stay on the pedal.
even if they have some off cuts from re-covering customer boards, works really well.
Postby Zak » Sat Jul 14, 2007 10:13 am
Thats a good idea, thanks man 8)
Zak
Postby Snoozin » Sat Jul 14, 2007 3:19 pm
Or go to a safety shop and ask for the adhesive abrasive grip stuff they use on stairs.
Snoozin
