Gull's new 98 Octane Biofuel
Postby Mr Revhead » Thu Aug 02, 2007 10:09 am
Prime Minister Helen Clark, who poured the first Gull biofuel at Albany on Auckland's North Shore yesterday, said efforts were being made to lift the standards of imported cars so New Zealand's car fleet would be less old and more able to use biofuels.
running that through my politician spin removal machine gives me:
uncle helen wrote:lets make the fuel companys provide fuel that you can only run in late model cars, thereby forcing ppl to gie up older cars. doesnt matter that that will force a lot of ppl to give up cars altogether as they wont be able to afford them, we'll be bending over to the greenies so we will look good
Postby darkwolf » Thu Aug 02, 2007 11:12 am
Can anyone tell me why carburettors are more likely to experience issues with this fuel? I would like to run it in my car but if it turns my engine into an external combustion engine I won't be happy. ENGINE:3S-F, 26 June 1989.
darkwolf
Postby Mr Revhead » Thu Aug 02, 2007 11:45 am
alcohol is corrosive.
i dont know how much this blend will actually effect things, prob not as much as some ppl claim, but over time it will cause issues, weather that time is 2 months or 2 years i dont know.
Postby cogent » Thu Aug 02, 2007 2:21 pm
might aswell burn this E10 in the 13b since its gonna run like shit anyway eh warwick :P
cogent
Postby Voyeur » Thu Aug 02, 2007 2:59 pm
Half right Warrick,
Ethanol is corrosive, but the main problem with carburettors, is that ethanol has a higher specific weight than the other crap they put in our petrol, couple that with long runners (longer than direct injection) there is a risk that the ethanol will fall from suspension and pool, in the bottom of the runners.
The problem with Japanese imports, is most of the seals in the fuel system are EDPM, if you change them to VITON, thenyou should be able to run the vehicle on ethanol based fuels, along with a retune.
Voyeur
Postby Mr Revhead » Thu Aug 02, 2007 3:02 pm
carbs re fuel falling out of suspension, mentioned that on page one :wink:
so its the seals? yeah i wasnt sure if the 10% mix would affect the carbs etc like 100% methanol would
could still possibly affect them over time though
Postby Voyeur » Thu Aug 02, 2007 3:20 pm
[/quote]carbs re fuel falling out of suspension, mentioned that on page one
Yea i saw that, just thought i would explain, before somebody asked why, exactly. You can run carburettor, as long as the port velocity is high, and not too long, it comes down to manifold design. K series engine should be ok. V8 with large plenium below carb not so good
Voyeur
Postby barryogen » Thu Aug 02, 2007 4:26 pm
Mr Revhead wrote:so its the seals? yeah i wasnt sure if the 10% mix would affect the carbs etc like 100% methanol would
They're talking Ethanol here... not Methanol... otherwise anyone with an alloy engine should be very worried 8O
http://en.wikipedia.org/wiki/Methanol
One of the drawbacks of methanol as a fuel is its corrosivity to some metals, including aluminium. Methanol, although a weak acid, attacks the oxide coating that normally protects the aluminium from corrosion:
6 CH3OH + Al2O3 → 2 Al(OCH3)3 + 3 H2O
The resulting methoxide salts are soluble in methanol, resulting in clean aluminum surface, which is readily oxidised by some dissolved oxygen. Also the methanol can act as an oxidizer:
6 CH3OH + 2 Al → 2 Al(OCH3)3 + 3 H2
This reciprocal process effectively fuels corrosion until either the metal is eaten away or the concentration of CH3OH is negligible.
barryogen
2ZZ Guru in training
Postby fuel » Thu Aug 02, 2007 4:38 pm
Mitsubishi All petrol engine vehicles since 1986 will operate satisfactorily on E10. Mitsubishi vehicles with carburettor fuel systems built before 1991 may experience hot fuel handling concerns and may experience a lower level of durability in some fuel system components.
Fkn awesome, so glad I have a fuel injected Mitsubishi right about now :P
LOUD NOISES!!!
fuel
Postby Mr Revhead » Thu Aug 02, 2007 4:41 pm
oh i know its ethanol, what i didnt know was how corrosive ethanol is compared to methanol.
Postby barryogen » Thu Aug 02, 2007 5:20 pm
Mr Revhead wrote:oh i know its ethanol, what i didnt know was how corrosive ethanol is compared to methanol.
Maybe we should take a closer look at Brazil where they already have massive amounts of Ethanol production, they seem to have solved many of the issues already, so maybe the issues are not as bad as they seem.
Most of what I have read about the corrosiveness of Ethanol seems to suggest that it is over hyped, and that it has less corrosive properties than tap water, I'm not a scientist, so I'm not trying to say I'm right, just that most of us here are very un-informed about it, and will probably need to read a fair bit about it before commenting with certainty.
barryogen
Postby Adamal » Thu Aug 02, 2007 5:57 pm
So how much is it gonna be per litre?
Postby no_8wire » Thu Aug 02, 2007 6:44 pm
less than 98 but more than 91...
no_8wire
Postby darkwolf » Thu Aug 02, 2007 6:46 pm
Adamal wrote:So how much is it gonna be per litre?
After Uncle Helen gets its hands on it and taxes it to cushion its "surplus" probably about the same price maybe higher than BP Ultimate.
darkwolf
Postby ee904age » Thu Aug 02, 2007 6:47 pm
I think approx 3c more than current 91.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Ae92typeX » Thu Aug 02, 2007 6:52 pm
$1.615pl at Gull Albany at present
Ae92typeX
Postby Adamal » Thu Aug 02, 2007 6:57 pm
I have to say, thats a pretty reasonable price in comparison to the rest of the market
Postby Ae92typeX » Thu Aug 02, 2007 7:09 pm
as long as it dosent corrode ones car away lol
Ae92typeX
Postby 2jayzgte » Thu Aug 02, 2007 7:10 pm
F**K I'm off to the airport to get Avgas and have no plans on using this new fuel.
2jayzgte
Postby Ae92typeX » Thu Aug 02, 2007 7:13 pm
lol, there goes your oxy sensor...not as scary as a flaming injector though
Ae92typeX
