d1 mule wrote:~SlideWays~ wrote:d1 mule wrote:i recon ya would hard pressed to get 250RWKW out of a 4age.
Im only running 17psi on the same turbo that IH8TEC has happily run 25psi on and my power atw is only 38kw off 250kw. And thats on smallish 510cc injectors too.
EDIT: unless you're talking about NA!? If so then yeah...a bit hard!
still ill believe it when i see it.
250kW ATW = 335HP ATW = 210Hp per liter
id like to see that sort of RELIABLE power on a street car.
iv got a mate with RB25DET with big turbo, GReddy inlet manifold 3 inch exhausts etc etc on a Llink it only made 330hp @the wheels. id like to see an engine with 2/3 the capacity make that sort or RELIABLE power
Sounds like a challenge to me
Lol nah 212kw atw is enough for me at the mo.
But just because a rb25 didn't make huge power, even though its got more capacity doesn't mean a smaller engine can't make more kw's.
One thing to think about is that RB's in NA for are pretty pitiful, leading me to believe they can't have very good head flow.
Compare that to a 4age (or dare I say it a b16 or 18) in their standard form they perform well. Being the fact that the heads are designed to flow well...help that along with forced induction and bob's your uncle
My setup isn't anything radical: No porting, standard cams, standard valves and valve springs, standard fuel pressure, standard 8.9:1 compression, etc etc. Slightly raised rev limit of 7800rpm.
Add 17psi and a decent tune and it made 283hp ATW.
I drive it to work in rush hour traffic, no probs, push it hard all the time, etc and no probs just a bung PS pump.
So add some cam's, port the head, bigger injectors (only reason the tuner stopped at 212kw's) and room for 8psi more. That would equate to a whole lot more than the 50hp needed to reach your 335hp atw.
Not trying to be a smart arse, just saying that 250kw's shouldn't be a problem.
