d1 mule wrote:you cant get 2mm and 3mm squared cables man. as i stated earlier, in TPS you get 1mm, 1.5mm, 2.5mm, 4mm and 6mm and so on.
95% of household ranges run a 6mm squared TPS dedicated circuit.
BZG|Bling wrote:Every new house i've worked on has a wire thicker to the cooker
(15A I guess) than the rest of the wiring, they doing it wrong these days?
Why even bother running a thicker wires to a car amp if the wires
not going to make a difference?
Just doesn't make sense to me. keen to learn something tho
Mike- wrote:1.5mm2 wire will be sweet for your cutter, provided its not too far away from your switchboard, a 15amp breaker wont trip until about 22amps neway and even then it takes ages.
go to a wholesaler and pretend ur a apprentice , ask for a 15amp standard 3 pin socket and pay cash (very cheap)
when u wire in, cut the old connections off, restrip it, twist and fold (just twist if theres more than one cable)
flygt4 wrote:Adoom you mincer.
can swing by at some point this weekend and check it out if you want.
being a registered electrician and all and i'm only up the road
can check everything is correct at the outlet and current draw is acceptable so everything is good on the socket end.
I won't be able to open it up and fix it though as itll most likely void your warranty. although i can think of a good possibility as to the fault in the unit itself
can leave you a plugin circuit breaker if you're lucky and your fuse base is the right type to accept it.
Adoom wrote:Yeh. NAH...Dell'Orto wrote:Give the starvia a roof chop
Dell'Orto wrote:Adoom wrote:Yeh. NAH...Dell'Orto wrote:Give the starvia a roof chop
Why not? It'll weigh less
Dell'Orto wrote:No no, a roof chop like hot rodders do....take a inch or 2 out of the pillars
Users browsing this forum: No registered users and 35 guests
