Spot the issues (3s-gte GTR Celica on TM)
Postby sergei » Fri Mar 13, 2009 6:39 pm
probably got BHG, as he saying was getting hot in long journeys.
Radiator size for 3SGE is same as 3SGTE from memory...
I would say this car is very dodgy.
Postby rollaholic » Fri Mar 13, 2009 6:41 pm
did mention its using water too
Postby AJz » Fri Mar 13, 2009 7:08 pm
rangi welding, hes prob running it at like 20psi, so it would be useless in the wet, no heat shield LOL.
stock ecu ftw ?
and yea im fairly sure the radiator in both my celicas were the same physical size.
The bov will be mounted there for more sound out the scoop bro !!!
I had vtax :(
AJz
Postby Scottie » Fri Mar 13, 2009 7:56 pm
taped up pcv lines?
Scottie
Postby Boosted_162 » Fri Mar 13, 2009 8:00 pm
AJz wrote:and yea im fairly sure the radiator in both my celicas were the same physical size.
They are exactly the same :wink:, i used a ZR one in my RC before i got the aluminium one :)
The part i find funniest tho...
trademe ad wrote:and being FWD, gets more power to the ground therefor is alot faster then a gt4
Hang on....did he say a single spinner gets more power to the ground than a 4WD?? What the?!?! :lol: :lol:
Postby deaf_rattle » Fri Mar 13, 2009 9:37 pm
could be worse?
what about this guy?
http://www.trademe.co.nz/Trade-Me-Motor ... 714900.htm
Postby trd_chik » Fri Mar 13, 2009 9:52 pm
lol 7grand, wtf
trd_chik
Postby rollaholic » Fri Mar 13, 2009 11:06 pm
funny to think hes spent good money to turn his car into a $&#$% eyesore
fake intercooler ftw
Postby barryogen » Sat Mar 14, 2009 8:26 am
postfach wrote:It's probably 6 of one half a dozen of the other
not an expert either, but from the reading I had done, it suggested pre IC as then it meant you were venting hot air, so the IC remained cooler... but, I can't see that mattering unless the IC was very close to being too small(overwhelmed/heatsoaked).
barryogen
2ZZ Guru in training
Postby soopachargen » Sat Mar 14, 2009 9:25 am
would it not be logical to vent it close the throttle body before it gets a chance to pulse back toward the turbo?
When in doubt, down and out.
soopachargen
Postby Audi » Sat Mar 14, 2009 9:55 am
I'm pretty sure this is worse. http://www.trademe.co.nz/Trade-Me-Motor ... 275305.htm
Yeahs it NZ new, but making out like theres only 4 or 5 widebodies in NZ! Shit I've seen far more widebodies around NZ then I have narrow. Claiming its got 260hp! Lovely 2-tone body kit, over 200k and starting bid is 10k! Good luck. Man if people out there buy this car for that much I sold my RC for waaay to little. :?
Dig a hole for the next man and you'll fall in.
Audi
Postby Boosted_162 » Sat Mar 14, 2009 9:59 am
Audi wrote:I'm pretty sure this is worse. http://www.trademe.co.nz/Trade-Me-Motor ... 275305.htm
Yeahs it NZ new, but making out like theres only 4 or 5 widebodies in NZ! sh*t I've seen far more widebodies around NZ then I have narrow. Claiming its got 260hp! Lovely 2-tone body kit, over 200k and starting bid is 10k! Good luck. Man if people out there buy this car for that much I sold my RC for waaay to little. :?
He is right about being only 4 or 5 in NZ, NZ new type As arent common. But its nothing special! Export models actually make LESS power than normal JDM spec GT4s.
And $10k, yeah right!! Id have trouble getting that for my RC i reckon.
Oh and since when did CT26 powered cars make more power than a CT20b one?? :lol: :lol: :lol:
Postby iOnic » Sat Mar 14, 2009 10:08 am
In theory.....closer to the throttle body is best. Works on the principles of inertial supercharging........why would you want that air rushing at the throttle body (when it's open) and then rushing backwards to the bov near the turbo.....and then the turbo having to accelerate the mass of air that still remains towards the throttle body again? :? Keep it flowing in one direction - towards the throttle. If the throttle is closed, the bov will be open.
In practice....you'll be doing well to notice any difference
:lol:
Can't see anything wrong with that celica other than being untidy. I'd sooner pay $3k for it than $2k for a blown up supra Ms Kettle.
Postby rollaholic » Sat Mar 14, 2009 10:12 am
man how does a car like that fall into the hands of someone like that?
its funny cos a couple of those three quarter shots which show the guards off had me feeling slightly moist! just needs to lose two tone / hideous bodykit and get some proper wheel fitment to fill those guards... could be sweet.
Postby mr2low » Sat Mar 14, 2009 10:42 am
that prelude wins hands down major epic fail, FRONT MOUNT, NO TURBO :roll:
mr2low
Postby soopachargen » Sat Mar 14, 2009 10:43 am
iOnic wrote:In theory.....
haha i just read that on tampa racing too :P
soopachargen
Postby trd_chik » Sat Mar 14, 2009 10:56 am
wAtch ur mouth youngin.
and 4 ur info hes keen as to swap mine plus cash my way. or should i say was
oh and one other thing if its the pot calling the kettle black that would make me the pot not the kettle :P :P :P
trd_chik
Postby iOnic » Sat Mar 14, 2009 11:36 am
sorry. my mistake. you're Ms Pot now :lol:
Postby AJz » Sat Mar 14, 2009 11:49 am
hi which gear does the turbo kick in im kinda new to turbo cars
trademe never fails to make me laugh.
a gt4 will do brutal launches if you do not care about the drivetrain. Gtr's would struggle laying down on a na 3s if you gave it too much beans, so good luck with that, lol
EDIT - omg it gets better :)
ive gota problem with how mine runs now ever since i put a boost tap on my mine to wind up the boost it cuts i think its running too much so i took it out, and now the car wont idol either im guessing it could be vacuum but im no mechanic, any ideas would be appreciated, thanks posted by: vinced
woot for vsv and boost controller, hello 18psi and limp mode :)
I had vtax :(
AJz
Postby Dazed&Confused » Mon Mar 16, 2009 8:47 pm
you could bet your bottom dollar this things blown a head gasket. maybe tired rings too, wont be the turbo burning oil.
Dazed&Confused
