Next time i get a dyno done i get it in rpms would make more sence then.fivebob wrote:Assuming the run ended at 7400 then the red 27(?)psi boost spike occured at 2800rpm, peak power is at 6600rpm and peak torque somewhere between 3500-4200rpm. All those figures seem to make sense to me.
Very impressive!!!
I will have to go back to torque to get it in rpms but as you can see on the dyno sheet in red i get full boost around 73kms thats about 1800rpm, on the runs he had done he as not hit the rev limiter so shutting off befor 7000rpmsstrx7 wrote:fivebob wrote:Assuming the run ended at 7400 then the red 27(?)psi boost spike occured at 2800rpm, peak power is at 6600rpm and peak torque somewhere between 3500-4200rpm. All those figures seem to make sense to me.
Those numbers make sense but they aren't what he's telling us
no not vvti engine, i can alwas build you a engine with the same specks as mine,strx7 wrote:I'm very interested as it would appear that your set up would make a interesting super saloon engine package.
I'm assuming its not a VVTi engine?
I already have a sper already worked none vvti 1jz head,strx7 wrote:VVTi on top of that package would give an VERY interesting torque curve.
I have a blue printed & Balance 2JZ bottom end which i will be putting a worked VVTi JZGE head on at some stage in the future (may take a couple of years)
With this new head i have now my boost just so quick, but even with my old set up i still had fast spooll up, that dyno sheet you have there do you know it thats race gas, that the sort of power if not more i am looking for, for next season.Lith wrote:Haha I have seen what a 50-75hp shot does to a 3litre engine running a 1000hp turbo on it before![]()
This is a dyno plot of an RB30DET with a slightly larger turbo than yours run without NOS, then the start of one where a similar shot to what you have is squirted into it where it prompted busted into wheelspin lol
Boost curve with NOS looks much like yours, if you have managed to do that without NOS then omfg.
audi man wrote:With this new head i have, the boost just so quick, but even with my old set up i still had fast spooll up, that dyno sheet you have there do you know it thats race gas, that the sort of power if not more i am looking for, for next season.Lith wrote:Haha I have seen what a 50-75hp shot does to a 3litre engine running a 1000hp turbo on it before![]()
Thats nice power if thats on pump gas, do you know what gear box that is.Lith wrote:Yeah that one is with race gas, but it has a pretty safe pump gas tune:
