2jayzgte wrote:GSD3 F-1s over everything mentioned especially when the roads or track is wet completely untouchable.If you want a source google Aussie Mag Wheels tire tests for the last 3 years the GSD3 F-1s have rated in the top 3 or won the tests.
sergei wrote:2jayzgte wrote:GSD3 F-1s over everything mentioned especially when the roads or track is wet completely untouchable.If you want a source google Aussie Mag Wheels tire tests for the last 3 years the GSD3 F-1s have rated in the top 3 or won the tests.
Only problem is that they test it when the tyre is new. The problem arises when GSD3 wears out to about 4-5mm, it looses traction big time.
Also people tend to shred them to bits on the track.
sergei wrote:Only problem is that they test it when the tyre is new. The problem arises when GSD3 wears out to about 4-5mm, it looses traction big time.
Al wrote:Need new tires for the Clio, the fronts are scrubbed bad, got wof at end of month.
Currently running Michelin Pilot Preceda's 195/50R15 they seem pretty good but are $250/each to replace.
Liked the Goodyear Eagle F1 GSD3's on the MR2, the only tire that tamed it in the wet. They are around $200/each.
Anything new that I should look at? Haven't bought good tires in about 4 years LOL
ihavelift wrote:+ 1 for getting noisy. Had them on my car. Just got a set of 225/45r17 Toyo CT-01s. and before anybody says it's a comfort tyre, they stick to the road like sh*t to a blanket. seriously awesome tyres, was sceptical but don't regret buying them 1 bit. Have had Toyo T1rs in the past, awesome tyre to but they wear out farken quick. my 2c anyways.
Users browsing this forum: Majestic-12 [Bot] and 26 guests
