ae101 gtz ( yup another advice thread )
Postby Cakky » Fri Apr 09, 2010 7:08 pm
just needs some rust work done around the windscreen, a few bits painted ( mudflaps etc ) and thermostat needs to be replaced, just pretty much got 20 year old car syndrome where everything needs fixing at the same time haha
1989 Corolla GT sedan blacktop 20v
Cakky
Postby TRD_ZERO » Fri Apr 09, 2010 11:38 pm
Mr Revhead wrote:I don't really think mr WOF man will worry too much about what that site says when talking about coilovers.....
Funny enough he does i have trd adjustable coilovers in my bzg and failed for having adjustabe coilovers. Showing him this piece of paper with definition he agreed and gave me a warrent. Cheaper than getting a cert when i dont need one.
Previous:
TRD_ZERO
Postby Mr Revhead » Fri Apr 09, 2010 11:56 pm
If you read the NZTA site you do need a cert.
It used to be that you use could that loop hole, but the LTSA (now called NZTA) closed it. They set the rules. Not the department of labour!
You cannot ues a definition from one source to decide on a rule from another organisation!
read this:
http://www.lvvta.org.nz/CertThresholdSc ... il04V3.pdf
Then scroll to the bottom where it gives the definition of "OE" re certs/wofs.
Take specific note of:
"at the time it was built and certified by its manufacturer"
That line excudes parts of a different type fitted later. In this case TRD coilovers.
When I was selling TRD often a selling point was not needing a cert, then they added the above definition to the rules and slammed shut that loop hole.
