Dont forget about it being a hot day...BZG|Bling wrote:Does it really matter though? I mean excluding for street cred
Seems like it used to be my car has XX Kw, but now it's my car has XX kW, but on a low reading dyno, so its better..... pretty sad / grasping for straws if you have to mention that imo.
Akane wrote:I prefer rolling road dynos, because it's power at the treads that matters, not at the hub.
solitaire wrote:Dont forget about it being a hot day...
metal_sean_head wrote:Akane wrote:I prefer rolling road dynos, because it's power at the treads that matters, not at the hub.
Only for wank factor. Dyno's are more of a tuning tool and to see power progress on the same dyno.
Lith wrote:Dynos aren't desgined for bragging rights - they are for tuning. Rolling roads are poos for guaranteeing that engine speed is relative to rollerspeed. I prefer not to run mine on rolling road dynos now as my car has a patchy history with them (first Toyspeed megameet was one of those). I don't feel like I can fully believe what the dyno is telling me is really happening.
Example, if you have facebook:
http://www.facebook.com/video/video.php?v=150291538325257&oid=322984464432
Resulted in a dyno plot with loopdeloopsd - car never feels like it does loopydeloops on the road though, unless you do something really silly.
Akane wrote:
Dyno is for both bragging rights and tuning, where do you think the term dyno queen comes from?
Your experience with them is quite unfortunate tho........
tsoob wrote:Akane wrote:I prefer rolling road dynos, because it's power at the treads that matters, not at the hub.
explain the difference...?
rollaholic wrote:besides, lap times / quarters etc are what count in my book. power is only part of the equation!
pjay wrote:I give my wife a quarter inch at a time.
solitaire wrote:Dont forget about it being a hot day...BZG|Bling wrote:Does it really matter though? I mean excluding for street cred
Akane wrote:You're driving on wheels, not hubs.
Luke - BZG wrote:Make sure you add the mandatory and very inaccurate %15 drivetrain loss if you want a bigger number.
Lith wrote:Akane wrote:You're driving on wheels, not hubs.
You're also driving on road, not rollers which control the speed the car accelerates at. They are every bit as removed from the real world as each other. The temperature of the day doesn't matter either as the correction the dyno software uses will attempt to adjust the power/torque curves to match what they would on a "control" atmospheric situation type day.
Some dodgy (or useless) operators will put their temp sensor in a really hot place and make the resulting figure real high, there are plenty of rolling road dynos around even in NZ which as run by the operators read higher than some of the Dynapack hub dynos around.
Akane wrote:The roller has a set resistance / braking effect which is a constant, and from the time it takes to spin up the rollers you can work out your torque. Having wheels on the car is at least 3 steps closer to a real road if not more vs a hub dyno
