In Car PC.......
Postby try_hard » Wed Apr 06, 2011 2:40 pm
You could build a computer with a ITX, Micro ATX motherboard or nano-micro ATX and throw that in ya glove box. i recommend ATX form factor as it is most popular and supported. With a power inverter wired into your ignition or any other source of 12V power/ignition the computer will only turn on with the reds on. but you will not have the computer turn on automatically that is imposable. If your link is connected to your PC through USB that will wake your computer up once the Link fires up if windows is configured correctly. you can have external devices bring the PC out of hibernation or sleep. and bobs your uncle. you just need a screen and input devices attached to your PC for control or optionally use a touch screen.
AE92 Trueno Sprinter 4AGZE
try_hard
Postby sergei » Wed Apr 06, 2011 4:19 pm
try_hard wrote:but you will not have the computer turn on automatically that is imposable. .
You can get an ATX power supply that can be programmed (and has sane default mode of operation) what to do when the ignition is switched on and off. It is definitely possible and I ran it successfully in the past.
http://store.mp3car.com/category_s/218.htm
Also don't bother with microATX form factor, when you can get an atom mini-ITX motherboard for ~ $100, that will also consume fraction of power.
Postby 3T-Rona » Thu Apr 07, 2011 11:24 am
cool guys cheers for the input and great advice,
ive picked up a cheap dvd/sd/usb/etc etc head unit that will do the trick for now so ill run with that.
the idea of an incar pc still intrigues me tho so it may be a plan for the future
cheers again.....
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
