Leon wrote:Where's that photo/slideshow thing of that Civic on mismatched tyres being turned into spare parts at Pukekohe when you need it ...
Not saying that's what *will* happen, but unless you're an old hand on the track, running lots more grip at the front can increase the risk of that sort of crash.
holden_fan2005 wrote:I found this a while back. Best if a track guru looks over it fist but that's what I'm going from.
http://planetsoarer.com/trackday/trackday.htm
ch4ng wrote:What tyre pressures have you run in street tyres (just to get an idea)
Im running 195/55R15
RobertC wrote:touge did you notice an improvement running the higher pressures? I remember at MM i was running 30 psi front and 28 psi rear hot. And i thought you were running similar. (I had loads more grip than when I was running 40 psi hot) On street tyres as well.
touge_ae101 wrote:i tend to dissagree. i had semi's on the front for the first 5 or so track days when i first went to the track and only stopped using them cause they wore out to the point where they aren't a lot better than a road tyre.
