Electric water pump prices!
Postby cat007 » Tue Feb 21, 2012 1:46 pm
Next question then is:
Would a stock mechanical water pump with the engine running at idle, and electric radiator fans on full blast, be enough to cool an engine down after a bit of a track session? Or do they only really start pumping enough water once the engine's RPM increase?
Postby xsspeed » Tue Feb 21, 2012 1:55 pm
Based on my corolla GT with partially blocked radiator.
I was having issues as only a corrosion inhibitor had been added, so no coolant. After some track time I came off and stalled, due to the starter being a bit weak I couldn't start and the water started to boil in the top tube as there was no flow.
Now when this had happened previously, water had been boiling, I was able to get it started and due to the flow at idle it was able to cool down.
Adding coolant 'fixed' this issue, (still suspect I have a partially blocked radiator, but haven't got to fixing this yet)
Postby xsspeed » Tue Feb 21, 2012 1:56 pm
So yes even just some flow helps, as it allows the heat to be transferred. Whether it is enough for your application is another question though - a few variables to work out there.
Postby pc » Tue Feb 21, 2012 5:48 pm
cat007 wrote:Next question then is:
...and I was about to say, Why not leave the car idling with the fans running? A fan override switch seems a lot cheaper and simpler.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby d1 mule » Tue Feb 21, 2012 10:58 pm
d1 mule
Postby cat007 » Wed Feb 22, 2012 3:15 pm
Very tempting to get the $135AUD EWP80
Should be well under $200NZD once shipping is accounted for.....
Not too bad really!
Postby DexGT » Wed Feb 22, 2012 6:25 pm
The EPW80 pump in the first link is $125 AU which is $160 NZ atm , so will be close to NZ$200 with freight so still cheaper than here unless it craps out .
I was looking at them a while ago and BNT had the 115ltr alloy pump with the digital controller for $495ish , be worth checking them for price.
DexGT
Postby spoonza6 » Thu Jul 26, 2012 12:53 pm
would it be worth running one of these on a NA Silvertop 4AGE?
or jus run the belt system as per normal?
im trying to fit a 4AGE into an EP82 so trying to make space in as many places possible
if not needed il jus go with the belt system
spoonza6
Postby Grrrrrrr! » Thu Jul 26, 2012 3:49 pm
Electric water pump will take up more space than the toyota one once you add the piping etc in. Unless the toyota one happens to be trying to occupy the same bit of space as something else (like a master cylinder) then I'd stick with that.
Grrrrrrr!
Postby Flannelman » Wed Aug 15, 2012 10:52 am
http://www.trademe.co.nz/motors/car-par ... 628571.htm
$495 for 115l/min alloy pump and controller
http://www.trademe.co.nz/motors/car-par ... 936034.htm
$495 for 115l/min plastic pump and controller
Flannelman
formerly known as Affroman
Postby gt4dude » Thu Aug 16, 2012 12:45 am
run fast idle and fan override
that davie craig might be mint for my w2a :D epic heat transfering
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Users browsing this forum: Google [Bot] and 19 guests
