The price of 4AGE T50's these days......
Postby Mr Revhead » Sun Dec 11, 2005 5:01 pm
yep i can understand that. but i dont think thats a problem in the toyota boxs
Postby Zak » Sun Dec 11, 2005 5:03 pm
Fair enough, I've never pulled a T50 apart so I couldn't tell you, GTX box's how ever.... :evil:
Zak
Postby matt dunn » Sun Dec 11, 2005 10:18 pm
Zak wrote:Dunno if it makes a difference on a T50 box, but in GTX box's putting better bearings in them makes them quite a bit stronger.
Because of the angle cut gears, the input and output shaft push each other apart and then s**t just hits the fan and all hell breaks loose in there :?
Yeah I severly doubt it.
We rebuilt a W5* series box with super strong expensive bearings in an effort to stop destroying them, but it made no difference to the life of them. They still only lasted the same time.
Matt
Postby turbo86 » Mon Dec 19, 2005 1:45 pm
better bearings dont make the gearboxes stronger it just makes it last slightly longer then the usually standard bearings, if you want to make your gear box stronger you get all the gears cryogenicly frozen and get steel selectors shifters made up. ( toyota w series box )
3sgte ae86
turbo86
Postby matt dunn » Tue Dec 20, 2005 12:08 am
turbo86 wrote:better bearings dont make the gearboxes stronger it just makes it last slightly longer then the usually standard bearings, if you want to make your gear box stronger you get all the gears cryogenicly frozen and get steel selectors shifters made up. ( toyota w series box )
We had a custom gear set made for the W55
and have had brass shifter forks made for the R154.
Matt
Postby turbo86 » Thu Dec 22, 2005 12:49 am
brass shifter forks for the r154? i thought those gearboxes were bulletproof. i used to have a jza70 supra factory 5spd with r154 and i couldnt break it, the car had a single to4 and gtr intercooler and 16psi boost and the gbox still took all the trashing fine. who did the brass forks would steel be stronger?
3sgte ae86
turbo86
Postby Mr Revhead » Thu Dec 22, 2005 8:35 am
hehe the dunns can kill anything :lol:
cept kp60 starships :lol:
nothing is bulletproof, EVERYTHING has its limits
Postby matt dunn » Thu Dec 22, 2005 12:06 pm
Mr Revhead wrote:hehe the dunns can kill anything :lol:
lol, I broke my 2k starlet, did a diff etc etc etc.
The R154's have been a problem in that car. It was actually a brand new gearbox thru toyota too.
I dont think it was a hp problem. There is actually two boxes for that car. One is usually in it and one is usually being repaired.
The car is due back this week and is getting a hollenger 6spd seq. fitted like the focus.
Matt
Postby Mr Revhead » Thu Dec 22, 2005 12:44 pm
nice. when do i get a drive? :lol:
Postby Si » Thu Dec 22, 2005 8:24 pm
Isnt there an issue with one of the input/out put shaft bearings on the 154?
i have pics online but i cant look at em as the hosting is down.
Current: , '96 SubaruImpreza
Si
Users browsing this forum: Bing [Bot] and 2 guests
