Got my car dyno'd
Postby Logan » Tue Apr 04, 2006 11:17 pm
well i had my standard blacktop in RWD format on the dyno last nite a hit 130hp at wheels (around95kw;s).
SR Sold. Onto Other Things
Logan
Postby Bazda » Tue Apr 04, 2006 11:18 pm
slighty_sykotic wrote:I have to say this..
maybe the speedworks dyno is up the $&#$%.....
Cause last week i got only 115kwish at 6grand (was still heading up at 6 tho, but we stoped it there) on my 4agze turbo.
And if you reckon you are even with blacktops, maybe you are higher than the dyno shows... cause i sure know my car is quick....like more than 115ish quick.
--Sykotic
same as the dyno i used, i got 140kws and i was doign 13.5@174
most other 4agte's were getting 170+ back then, but my 1/4 was better by far.
Postby Drifter4ag » Tue Apr 04, 2006 11:30 pm
you reakon ?
mine was done on torque pulled up 176 and 13.2 @173 ... pretty close ... i say that the speedfact0r dyno or whatever is reading no good...
1/4mile is your best bet on rough power
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby bluemaumau » Tue Apr 04, 2006 11:33 pm
comparing engine figures/dynos with 1/4 miles will never work.
theres one changing variable; people :wink:
Postby Bazda » Tue Apr 04, 2006 11:36 pm
Drifter4ag wrote:you reakon ?
mine was done at Shore Performance, i got 140kws back those days with a t25g hybrid. Urs was launching way better than my car for sure.
I put on the bigger t3/4 it felt faster but not like WOW faster and did 12.9@180 but never got it on a dyno.
Postby Drifter4ag » Tue Apr 04, 2006 11:37 pm
ahha. .. i had a 2.8second 60foot on my best run !!! surely yours was better than that ?
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby Bazda » Tue Apr 04, 2006 11:38 pm
Drifter4ag wrote:ahha. .. i had a 2.8second 60foot on my best run !!! surely yours was better than that ?
oh lol yea mine was 2.4s back then
how the hell u only get a 2.8, i did that if i bogged the launch
Postby Drifter4ag » Tue Apr 04, 2006 11:54 pm
it just wheel spins to hickory .. no matter what i did i couldnt stop it .. but its better now .. a shame the car no longer mine ...
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby Caveman » Wed Apr 05, 2006 8:32 am
Id say the 7000RPM would be incorrect. If they balls up the diff ratio at 4.6 then its probably more like 7400RPM.
XS1V recently replaced a bluetop in his ae82 with a silvertop, recons the silvertop goes slower :lol:
Caveman
Postby HELBND » Wed Apr 05, 2006 9:09 am
1998 wrote:Id say the 7000RPM would be incorrect. If they balls up the diff ratio at 4.6 then its probably more like 7400RPM.
yea but thats cause he put in the rooted as old silvertop from his levin - that thing was F*CKED 8O
HELBND
Postby Mr Revhead » Wed Apr 05, 2006 11:02 pm
yeah, if you out a 20v in a bluetop car and its slower, you $&#$% something up
Postby Loudtoy » Thu Apr 06, 2006 8:52 pm
Mmm, Boost wrote:When we dyno'd GT Girl's AE101 FX GT it made peak power at around 7400rpm I think, may have been slightly higher. I dont think Brent is very familiar with Toyotas, hence why not revving it right out, unless it was pinking at that point. I know he refused to dyno one car around here cause it was too noisy (VVT pulley rattle).
My one was peak at 7600, mid you that had a little bit more in the breathing department than hers both sides of the motor, made 93kw on about 3 different ocasions that silvertop which is fairly close to most blacktops with the same mods - oh and for those of you who want brand names of the gear i used was hws gear :) Quite cheap for how well it worked although sometimes i think it could have done with a beter quality finish just for looks. Oh and seeing as people are comparing kw's and 1/4's my best was a 14.77 at 94mph :)
AE85coupe wrote:
oh and my car weighs 950kg
so yeah
suck my balls
Tsk Tsk check my sig for racing weight, now you could have stripped yours out and i reckon i still would have taken you to the cleaners, track or drag strip :P
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Al » Thu Apr 06, 2006 9:39 pm
bluemaumau wrote:comparing engine figures/dynos with 1/4 miles will never work.
Don't talk crap. Trapspeed on the 1/4 is the ultimate dyno. Times are just how well you can utilise the power.
Al
Postby 10k 20v » Thu Apr 06, 2006 11:51 pm
my first dyno on my old silvertop was 103 kw at wheels at torque performance, then 108kw at wheels, of course it was modded, then my stock blacktop made 102kws at wheels and it felt way slower than my silvertop at 103kws even tho it wasnt.
Its amazing what a smooth torque curve does to your perception of speed.
Thats why turbo's feel as fast as they do when the coming on boost :)
10k 20v
Postby JRS » Sat Apr 08, 2006 3:32 pm
i've never seena dyno being used. does it not use some sort of inductive pick-up to work out the RPM? just some gear ratio pulled out of the operators arse?
meh.....
JRS
Postby pc » Sun Apr 09, 2006 7:54 pm
You can only use the trap speed if comparing mods in the same car. car aerodynamics and power 2 weight will affect trap speed significantly.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Drifter4ag » Sun Apr 09, 2006 10:01 pm
FFS aerodynamics ? ahaha make me laugh ...
trap speed is a good test of power.. and yes you need your weight to determine the power of your vehicle from trapspeed
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby Loudtoy » Mon Apr 10, 2006 8:05 pm
Drifter4ag wrote:FFS aerodynamics ? ahaha make me laugh ...
You reckon?? Trap speed is mostly a check to see who can drive there car off the line the best eg; in the same car i have had variations of 9mph trap speed in one day 4 different runs as i got dialled in to grip off the line or lack of, 1st run highest trap worst et 3rd run lowest trap best et. Now you can't possibly tell me that my car gained x amount of horsepower through the day as it got hotter and less humid as the day wore on.
Trap speed will only show you power is greater in one car over the other if the weight is exactly the same and both cars have exactly the same 60 time as each other - oh and no wheel spin for either after the 60 foot mark and only 1 gear with unlimited top end kind of like a big cone drive constantly varying. Otherwise there is to much variable in drivers and cars to compare them this way.
TS Member sine 2001
Loudtoy
Re: Got my car dyno'd
Postby avinesh » Thu Apr 13, 2006 3:32 pm
trueno_20v wrote:Well took my car to speed works today for a run on the dyno before it gets turboed..got 70.3 kw atw's @ 7000 :oops:
damn silver tops are soooo over rated on paper aye, only 70 wkw on a hub dyno..... i got my car dynoed its a gen 1 b16a with intake header an exhust an got 115.5 wkw on beyonds rolling road dyno.....
avinesh
Postby JT » Wed Apr 19, 2006 12:18 am
Loudtoy wrote:You reckon?? Trap speed is mostly a check to see who can drive there car off the line the best eg; in the same car i have had variations of 9mph trap speed in one day 4 different runs as i got dialled in to grip off the line or lack of, 1st run highest trap worst et 3rd run lowest trap best et. Now you can't possibly tell me that my car gained x amount of horsepower through the day as it got hotter and less humid as the day wore on.
Nah, even if you miss a gear (not within the last 60ft obviously) or spin up bad off the line your trapspeed should still be within a 1 or 2 mph. There's something very wrong if you are getting 9mph variance, like say the timing gear at MMP :lol:
Your ET is how well you were able to use the power.
avinesh wrote:damn silver tops are soooo over rated on paper aye
Thanks for that insightful piece of knowledge
JT
