Mr Revhead wrote:toyota v6s are put in camrys for a reason.....
they are reliable, if anything
MikeMan wrote:I would have a look at the 6G72 MIVEC 3.0l V6 out of a 30M Diamante.
It puts out 180KW stock and should be fairly easy to get to 190-195 with some minor work.
260HP at FW would make the 220GTi move I think.
fuel wrote:MikeMan wrote:I would have a look at the 6G72 MIVEC 3.0l V6 out of a 30M Diamante.
The 6G72 MIVEC actually puts out close to 200kW stock.
The trouble is, it is an iron block construction, quite large and heavy. The original poster is looking for a lightweight all alloy engine to put into his Rover which originally had a 4 cylinder engine.
MikeMan wrote:
Does it have to be an NA V6? I am thinking something like a SR20DET might be a better idea if the M16 is not an option any more.
GT4 20 wrote:Thanks for the offer but 1600cc is too small.
Gary
GT4 20 wrote:
Yes. The T16 (M series was earlier) was turbo and I don't want to go down that route for many reasons. NA V6 will be a good source of torque, more so than most 4 pots.
Gary
saft wrote:in defence of the sr20det, the parts are cheap, they make lots of torque, they are a known quantity when it comes to building for a certain power level, and there are plenty of local companies with experience building them
Stu- wrote:Just as a side note : how's the rest of the rover going? Last time I saw pics of it you were getting a cage and had a side exit exhaust? Any updates?
GT4 20 wrote:
Not sure what Class C rules are, but with engine, I anticipate the all up weight being between 1000 to 1100kgs.
Gary
MikeMan wrote:
The 3.0L is rated at 180KW. The 3.5L (as used in the Evo Pajero) is 206KW.
