Some real manifolds
Postby vvega » Thu Dec 07, 2006 9:06 pm
depends on how many pulsed you plan to use in your scavanging
and strx7
automoive companys spend a lot of money making production cars make good hp and are reliable
unless you own a caldena :d
as for mainfold material
steam tube makes a good compramise
and stainless is shit because it loves to move when its hot :D
though you can fix that with some careful planning and prereleaving
if you wanna talk engineering im happy to
but realise i do it for a living.... and have been there and done it
as for ex physics......the only real differance is the heat IMO
and gmacrae
have you ever seen a proper split pulse manifold ??
one with 2 wastegates ??
cause as soon as you join the to streams.....its a waste of time
90% of teh manis you can buy have a single wastegate and is potentially why you dont see advantage
rotarys ?? and piston engines ???
there both air pumps just ones a 2 stroke
do some thery and have a think about it :D
v
vvega
Postby Crucible » Fri Dec 08, 2006 7:43 pm
vvega wrote:cause as soon as you join the to streams.....its a waste of time
hmmm interesting, that makes sense
My split pulse manifold, (barrys old one) only uses the one wastegate, I know its divided where the two join with a plate but probley wouldnt be completely sealed, wonder if its worth the effort running twin gates???
I thought the plate was there to just keep the flow on path.
I see now why barry uses twin gates, thought it was just a bling feature..
Crucible
Real Life Mechanic
Postby RedMist » Fri Dec 08, 2006 8:43 pm
strx7 wrote:
sergei wrote:I think it is opposite => higher revs shorter runners (reasoning is due to wave length being shorter at higher frequency)...
correct, same with inlet manifold runners
Not strictly true. It totally depends on the number of reflections used in the helmholtz calculations. A 4 reflection primary may be shorter than a 3 reflection primary, but the 3 reflection will be tuned for higher RPM. IE longer, but tuned for higher RPM.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby vvega » Fri Dec 08, 2006 8:46 pm
vvega wrote:depends on how many pulses you plan to use in your scavanging
v
muhahahahah
vvega
Postby Bazda » Sun Dec 10, 2006 9:46 am
anyway.
back to the topic, all fitted etc, racing at pukekohe on the 17th Dec.
Come listen to this escort down by the hairpin cos it sounds magic!
