Lith wrote:I didn't pick up on the wastegate on the pressure side of the inlet setup to control boost - really doesn't sound like a good idea to me, wouldn't it be creating what is normally considered a problem? Ie, an air leak while under boost?
If the thing ever reaches enough pressure that the "wastegate" needs to be opened, then the turbos are still going to behave like they are freeboosting - but the air isn't going to go into the engine. The turbo bearings are still going to take the full brunt of potentially excessive RPM and the air will still get heated quite nicely. Airleaks are a big turbo killer....
smithers wrote:The pipe that comes off the wastegate, (the screamer), does that vent to atmosphere? What psi spring is in it? And when it opens when its driving, what will the motor do? Will it just halt in making power and die?
Though, very interesting
matt dunn wrote:Seems that as long as the turbo's are sized accordingly, and the BOV is also sized accordingly,
it all works perfect.
My bet will be the w58 gives up before the rest.
Si wrote:Just give it a 250HP shot of NOS to help it spool
gmacrae wrote:I'm all for innovation, but this thing has all the disadvantages of a 1500hp monster (no power below 6k rpm), and only 700hp worth of fuel? Why not just use one t70? If you are planning on making use of the huge flow of those blowers (with more fuel), why not spend some money on replacing the stock intake manifold? What do you think you're achieving by running free boosting turbos? A pre-turbine wastegate will always be more efficient than a post-compressor wastegate.
Sorry man i just dont see the pointlooks great tho.
This needs to be a pretty long explanation to fully understand ALL the reasons for and against the reasons I some times use wastes gates,blow off valves, or even some times both.
But first a little history. Back in the days of early Rb 30 development this would have been about 1988/1991 we were starting to make some really good numbers about 500 hp,and the turbo's that were available were not up to today's standard, nor were the waste gates, you could get I think from memory a 42 mm Garrett was the best we could get and it was a big bulkie thing so fitting it in the car with extractors and turbo was also difficult, this then lead to the fact that trying to get lots of flow to it was also hard.
Now the next problem was trying to hold high boost levels at high rpm above 6000, by this time the turbos were running out of puff so the waste gate was completely shut anyway,I now see this happening again at events like dyno challenge days were people are trying to get huge
hp numbers.
So the only place the waste gate was working was in the mid range, and because at that point the engine still had good V.E. we were trying not to put to much boost into them as they would break con rods above 500 foot pounds of torque. [Sound like the BA, a history making lesson for the future]Now because the waste gate were A too small and B you didn't have enough room in the engine bay to place the gate in a good flowing position the damn things would not control the boost, and they would boost spike, wammo broken engine. So the answer we came up with was to add a blow off valve or as we called it an over boost valve, that was set to a maximum pressure that would 'nt destroy the engine through to much torque.
Now all of a sudden we thought well if the waste gate was not doing its job in the mid range and it was fully close at the top end why bloody have it. So in the bin it went.
We now started to control the blow of valve electronically with the boost control output Thur the Motec and we found we had better control than ever before.
As far as over speeding the turbo goes remember two things, firstly the waste gate was fully closed at the top end anyway, and so is the blow off valve for that mater,so there is no difference at that point. Secondly the turbo is driven by exhaust gas and that gas is being created by the air entering the engine, so if you blow some of that air off it never gets to make exhaust and then never gets to spin the turbine ,hence speed is also not greatly effected.
There are also plenty off other reason why we do now use waste gates in conjunction with blow off valve but I'll get to that in another 5 years or so
matt dunn wrote:As far as over speeding the turbo goes remember two things, firstly the waste gate was fully closed at the top end anyway, and so is the blow off valve for that mater,so there is no difference at that point. Secondly the turbo is driven by exhaust gas and that gas is being created by the air entering the engine, so if you blow some of that air off it never gets to make exhaust and then never gets to spin the turbine ,hence speed is also not greatly effected.
IH8TEC wrote:big ups to you simon for seeing similar setups, and deciding to give it a go, and "experiment" with it. not many people would.
why not people instead of critisize it, just wait and see how it works
gmacrae wrote:Good explanation Lith, hope everyone read it.
Mr Revhead wrote:using a pop off valve on the intake has been used sucsessfully in motorsport for years. ie CART, F1, WSC etc
the key, as with all aspects of modifying cars is correctly matching the components.
Mr Revhead wrote:hehe yeah but u cant do that mid race![]()
the big thing you have to remember with the nizpro set up.... is they have it working![]()
i cant see any issues with it. in the right application
Users browsing this forum: Bing [Bot], Truenotch and 23 guests
