Where to get blacktop trumpets?
Postby Distrb » Thu Jul 03, 2008 4:50 pm
Crampy wrote:How do we work out or know the ideal length for a Blacktop, other than chuck them on a dyno and look at the power deilvery?
Depends for what purpose you are wanting the trumpets. And what other work has happened to the engine internally as well as what ecu you have running the engine, before you can really define what is 'ideal'
The factory ones i measured crudely at around 125mm in length. Although even with the same length ones, you lose resonant frequencies that having the chamber around them creates (Helmholtz) There is a large amount of science around it that i dont understand properly.
In my very limited experience with mucking around with the trumpets, the longer you go, the lower down the rev range the torque curve will move, and the shorter they are, the higher up it will go.
A large school of thought shared by many here says that the best trumpets to use are the factory ones with the airbox and intake chamber.
I'm planning on buying a couple of those 150mm sets from efihardware for my race car with blacktop 20v in it, and gradually decreasing the length of the trumpet from standard to see which is going to be the most effective for me with the engine setup i have.
Distrb
Regular Poster
Postby Crampy » Thu Jul 03, 2008 5:01 pm
Sweet.
I had some 75mm ones onf my BZ-G, but had filter socks on them too. they were no good at all. With them off the car ran way better. No filters is not so good for a street driven car.
The BZ-G was good when in the higher revs, down low was not so good, but acceptable for me.
I'm looking at putting a Blacktop in me AE92 and eventually will put some straight ram tubes in it. I think it'll be a matter of the longest ones I can get in there without getting too close to the firewall and clutch fulid reservior. I'll put a good size air box in there and run a panel filter on the top of it, with a bonnet scoop feeding in the air (mainly because I have a Subaru scoop sitting in with my stuff).
I might get the long tubes and do a back to back dyno run with stock intake and tubes, then the aftermarket tubes. Just to see what happens. If it turns out the stock ones are better, I'll keep them and sell the straight tubes.
Crampy
Postby FST4RD » Thu Jul 03, 2008 5:35 pm
http://www.tweakit.net/shop/product_inf ... 516d5f1fff
I think these are the ones that he might have got....
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
