Wanting info on Hydrogen engine conversion
Postby fivebob » Mon May 26, 2008 2:36 pm
sergei wrote:For people who need more than 300kms (which is possible to have right now with current battery tech.)
How many KW can you get with that 300km range?
there is an option of either battery swap station
Is that really practical with current battery technology???
It's not like there is just one battery and they are not exactelt easy to get at is most vehicles due to the face they take up almost all of the available space.
or back up generator trailer and yes, it will have to run on something, but think about it it has to be about 20kW tops, and can run say on McDonald's oil or methanol/LPG whatever more efficiently then normal ICE as it runs only in narrow rpm range where it is most efficient, it can even be a small gas turbine (40-50% efficiency vs 20% for piston tech.) or a methanol/methane/hydrogen fuel cell,
Why put it on a trailer???
Surely what you describe is a hybrid car without the benefits.
or another option "15 min" recharge station just like current petrol station with beefy 100A charger.
15min recharge!!! What battery technology are you planning on using, certainly not any of the current commercially avaiable Lithium cells, their minimum recharge time is 1 hour, and even then they need time to cool down before and after charging, so their turn around time is around 2 hours. Lead acid wouldn't take that charge rate either, so you're left with NiCd or NiMH.
Even at 100amps you're limited to a very low Kw motor assuming 300km takes 3.5 hours, with a 90% efficient motor you'd need to be running 350v @400amp.hrs to run a 40kw motor for that long. So even if you used 10a/h NiMHs you'd need 12,000 of them. They'd have a total combined weight of over 2 tonnes and take up 2.5m3 of space. Even ignoring the retail cost of $300,000, is that't really a practical long distance car?
Honestly I don't think current commercially available battery technology will work when it come to fast recharging. There were some experimental Lithium batteries that promised a 1 min charge time, but the cost was astronomical and the life was very limited. Even if you could find a battery with a short enough charge time the voltage and current requirements make it a very dangerous propsition.
Postby sergei » Mon May 26, 2008 2:50 pm
I would say with 40kW(nominal) motor it is possible to get 300kms, don't forget that it is not a constant 40kW drain, although usually 40kW motors will handle 60-80kW peak but obviously if you are using constantly 40kW you are going quiet fast. normal driving averages a lot less power.
Anyway I took 300kms from Tesla Roadster example.
as for 15min recharge I was thinking of NiMH (if it wasn't for Exxon Mobil).
Trailer is good idea because you don't have to carry ICE/Generator/Fuel around if you don't need to (most of commute driving).
Here is good read/watch http://www.metricmind.com/ac_honda/main2.htm and http://www.metricmind.com/audi/main.htm .
Very interesting projects (and very expensive).
EDIT: Apparently the dude behind these projects is Russian 8O
Postby fivebob » Mon May 26, 2008 3:25 pm
Ok halve it to 20kw, still need 1 tonne of batteries @350v and a 35kva recharge source.
Postby neon_spork » Mon May 26, 2008 5:12 pm
The kilowatt hours of your battery will determin the range, not KW of the motor or battery. (we are talking energy vs power) KW of the motor will determin how fast you get there.
If you have say a 3.7V, 3.5Ah Lipo cell you get 12.95 watt hours. To get a reasonable 25KWh's you would need about 1930 cells. At USD$5.50 a cell thats ~ USD$11K.
Cant remember the mass of a cell but they are quite light.
I figured that you would need about 50KWh to get around a 300km range, I think that was based on the tesla car.
neon_spork
Postby sergei » Mon May 26, 2008 5:14 pm
neon_spork wrote:The kilowatt hours of your battery will determin the range, not KW of the motor or battery. (we are talking energy vs power) KW of the motor will determin how fast you get there.
Yeah that is quiet right and similar to my calculations that I did on other thread that I started.
Postby pc » Tue May 27, 2008 12:42 am
Shouldn't the weight of the batteries be factored into the calculation? As the weight of the batteries goes up, the power you need to push the car around with the target acceleration rate (whatever that might be) goes up.
I'm guessing here, but 40KW of motor per 1000Kg of car?
Is it linear like that?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby molex » Tue May 27, 2008 1:10 am
Part of driving an energy efficient vehicle is driving efficiently, you don't need a 40kw motor to maintain a cruise. More like 10kw or less for 60km/h
I agree that current energy storage methods don't cover all bases but they do cover the daily commute for the vast majority of the population. Those of us stuck in the stop and go crawl to and from the office daily never get above 50 km/h anyway. Electric motors are *excellent* for stop and go traffic. They don't idle, they don't stall, there doesn't need to be a clutch/complex automatic transmission, they have virtually max torque from zero rpm and can regenerate limited quantities of energy over and above their already high efficiency. If as much effort was expended on electric as it is every year on ICE cars we would have something very workable by now.
molex
Postby barryogen » Tue May 27, 2008 10:01 am
sergei wrote:it can even be a small gas turbine
With the most awesome side effect of a wicked sound where ever you go :)
barryogen
2ZZ Guru in training
Postby sergei » Tue May 27, 2008 10:31 am
I have plenty of those (ideas) just no $$$ money to implement so I "bin" them ;)
Postby barryogen » Tue May 27, 2008 10:39 am
barryogen
Postby sergei » Tue May 27, 2008 10:45 am
It is not the "Hydrogen" kit, it is one of those bull shit hydrolysers.
Re: Wanting info on Hydrogen engine conversion
Postby Voodoo » Mon Jun 09, 2008 10:04 pm
Adamal wrote:With fuel prices going up, and me becoming (for some inexplicable reason) more environmentally concious, I've been wondering if perhaps hydrogen is the solution to our problems.
However, I only have limited knowledge on the stuff.
I'm interested in what it would take to convert to a hydrogen system for an internal combustion engine, what possible problems could be etc. I read something about it causing backfire on piston based engines, but it didn't go into detail.
I know there are some smart cookies here on TS (Yes, hard to believe, I know :P) and was wondering if anyone could point to some reliable information that isn't overly difficult to understand for the average Joe Bloggs like me.
Not really after information on Fuel Cell's, just internal combustion stuff.
Thanks guys :)
Just saw a tv article on the news here in aussie , about two guys running a Hydrogen setup on a old falcon , its getting mixed in with the normal fuel at the intake , but is saving around 20% in fuel cost
Voodoo
Postby matt dunn » Mon Jun 09, 2008 11:51 pm
A guy an my father in-laws work is doing that on a diesil Toyota ute,
current draw of about 3A and creating the hydrogen which goes directly into the intake.
not enough to run the vehicle, but is hoping to just help with economy a bit.
He's going to run it for a while and see if there is a noticeable difference.
Postby pureadrenalin » Tue Jun 10, 2008 1:42 pm
sergei wrote:...battery swap station....
Exactly.
Why can't there be a swap-a-battery just like there is for BBQ bottles at the gas station, or beer crates at the bottle store 8)
And it can even start with dumb old lead acid racks of battery's if you want.
Just as long as later "models" (Ni/MH, etc) fill the same space. All that will happen is your range will increase as the battery's get better!
Duct tape is like the force. It has a light side, a dark side, and it holds the world together
pureadrenalin
Postby sergei » Tue Jun 10, 2008 2:40 pm
To continue the idea of battery swap station, why not have a lease plan on the battery when you buy car, instead of owning it.
This way car will become a lot cheaper to start with.
Postby MAGN1T » Tue Jun 17, 2008 6:05 pm
I doubt it will make any difference on a Diesel, it will with petrol though.
The problem with petrol engines is that they're extremely inefficient at part throttle, all you need to do is to increase the thermodynamic efficiency at part throttle and you get big fuel savings. It won't increase power output at full throttle though.
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby barryogen » Thu Jun 19, 2008 10:31 am
in the latest top gear NZ mag they have an article on a new Morgan that is only has only 22kw, weighs ~650kg, does 0-100 in under 7 seconds and has a range of ~400km, top speed of 135km/h. 2 seater, very retro hotrod/saltflat racer looking.
No mention of when or cost though.
linkage...
http://www.morgan-motor.co.uk/lifecar/lifecar.html
barryogen
Postby ChaosAD » Thu Jun 19, 2008 7:01 pm
Wont the greenies get all upset about using all those batterys? How are you going to dispose of them when there life starts getting short?
What ever happened to lpg/cng? everyone used to be converting there cars but you dont hear much of it now. Why not just use the methane instead of converting it?
ChaosAD
Postby Dell'Orto » Thu Jun 19, 2008 7:13 pm
Plenty of LPG still around, I have acouple of customers who do conversions and they're flat out.
Postby Trls250s » Thu Jun 19, 2008 8:35 pm
I just finished building the hydrogen convertor part of one of these, mine draws a healthy 12Amps, but it cranks out the hydrogen. Will let you guys to know how it turns out.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
