KinLoud wrote:Warwick - my comment was about about speed displays in Victoria not in NZ
Ken
CXGPWR wrote:GPS are slow and will give you an estimated speed by calculating between two points. unless you spend thousands on a fantasticly amazing gps they will allways read slow.
Mr Revhead wrote:So, your average speed between two points. I would assume those two points would depend on how many sattellites you're picking up at that time?
Not your realtime speed.....
Malcolm wrote:Typical accuracy for a GPS unit should be within 5m with a good signal. If you're driving slowly, you cover say 5m in the time between two calculations and each calculation is off at the worst limits of accuracy it could think you've done 15m and therefore give you a 200% error in speed. If you're going so fast you've done 500m between readings (unlikely) then 10m difference in that distance will only give you a 2% error.
pjay wrote:sergei wrote:I am sure that my speedo is accurate because I measured with GPS/calculators/Your speed is signs and it is accurate within 1kph
Users browsing this forum: No registered users and 29 guests
