Whats Your Revs To Speed?
Postby no_8wire » Sun Jan 29, 2006 6:45 pm
1loose_mr2 wrote:aw11 does about 1300 @100 and about 4000 at 180 with over switch on
You must have a seriously long top gear!....
no_8wire
Postby ae82gt » Mon Jan 30, 2006 12:44 am
slighty_sykotic wrote:mine is damn near dead on 3500 on a 1991 ae101 20v, with 205/40/r17 tyres at 100km/h......i sometimes wish it was lower (6 speed? :twisted: ) simply to reduce cabin noise a bit.
No other ae101 people reading this thread?...
--Sykotic
sounds like you need a c56 box mine 20v runs 3000 @100 on 205/40/17
fxgt ae82 20v
fxgt ae101
ae82gt
Postby cespenar » Mon Jan 30, 2006 8:35 am
Bout 3100 @ 100
96 Supra SZ
cespenar
Postby flygt4 » Mon Jan 30, 2006 5:25 pm
ae101 , with ae92 gtz gbox.
3100rpm@100km in 5th
itll also do 107ish in 2nd and 165 quite rapidly in 3rd revving to 8000rpm. no idea what it goes to in 4th or 5th as the cars engine has bigger balls than i do :wink:
id hate to think what the theoretical top speed would be in 5th,but i suspect itll do 220-230 in 4th :?
flygt4
Postby no_8wire » Mon Jan 30, 2006 6:10 pm
flygt4 wrote:ae101 , with ae92 gtz gbox.
You must have longer gears than me....
no_8wire
Postby flygt4 » Mon Jan 30, 2006 6:24 pm
yeah ratios are a bit funny as its a gtz gearbox revving to 8000+..
makes for a good 100-165km sprint tho.
flygt4
Postby Truenotch » Tue Jan 31, 2006 2:27 am
--Sykotic
It'll be the 17's making that difference
Truenotch
Postby AirNZ » Tue Jan 31, 2006 9:24 am
My AE92 fxgt did 3400 at 100km/h. Always seemed a little up there while driving, but made it a lot easier to overtake without downshifting so long as the road was flat. Even made it up the bombay hills all in 5th at 105 with a full load.
AirNZ
Postby Punter » Tue Jan 31, 2006 9:35 am
--Sykotic
Wheel size won't change the speed shown only your actual speed. (unless adjusted)
Punter
Postby Jazza » Tue Jan 31, 2006 1:27 pm
Mine does 2900 at 100km in 5th... weird... for a small engine i woulda expected higher...
1996 Curren - On Tardme
Jazza
Postby Silent Knight » Tue Jan 31, 2006 2:17 pm
Jazza wrote:Mine does 2900 at 100km in 5th... weird... for a small engine i woulda expected higher...
AFAIK the biggest contributing factor for speed @ rpm will be your gear + diff ratios and not engine size...
Silent Knight
Postby CozmoNz » Tue Jan 31, 2006 2:46 pm
yeh, but generally bigger engines are geared higher.... (commonwhores, geared to 340 or something arnt they?), and also only do 1500rpm at 100kph.
Rayne For President!
CozmoNz
Postby 20v_rollaboy » Tue Jan 31, 2006 7:31 pm
my 20v rolla does about 2900rpm in fifth doin 100kph
will also do 120kph in second, revving to 8000 8)
20v_rollaboy
Postby UTERUS » Wed Feb 01, 2006 6:30 pm
The soarer sits at 2100 in overdrive at 100km/h
It is a myth that emos are contagious, and you may be infected. However, it is still widely accepted to wash your hands after physical contact
UTERUS
Postby Ae92typeX » Wed Feb 01, 2006 8:38 pm
my brick sits just over 4000 at 100...lol, not much left after that either
Ae92typeX
Postby avinesh » Wed Feb 01, 2006 10:18 pm
my integra does 3500rpm @ 100, will do 95 in top of 2nd at 8500 rpm..... 8)
avinesh
Postby bad20v » Thu Feb 02, 2006 10:43 am
BZR's got a new gearbox now....
2900rpm @ 100kph in 6th...... cruise mode. 8)
Thank-You.
bad20v
Postby Ako » Thu Feb 02, 2006 10:59 am
Man these toymota thingys have long legs for the size of them!
VR4 was 3200 in 5th @ 100
2nd got me to about 90km/h @ 8200rpm, 3rd was about 135 at same revs, 4th hit the limiter at exactly 185, 5th.... Well, to hit the end of it I had to disconnect the speedo :twisted:
Ako
Postby barryogen » Fri Feb 03, 2006 11:38 am
2900ish @ 100kmh in 6th
01 Toyota Corolla RunX
C60 GB.
205 16 55s
barryogen
2ZZ Guru in training
Postby Norty » Fri Feb 03, 2006 2:37 pm
AE101 Levin
3000RPM doign about 110km or 115km on 205/40/17
i know 100KM is under 3000 myabe 2700RPM
5th gear BTW
Norty
