What type of tyres do you have?
Postby B_giB » Mon May 03, 2010 9:57 am
rolla_fxgt wrote:Re001's are good.
But they can be a bit slippery in the wet if your pushing it. Still they're 100 times better than MY-01's which are worse than almost any other tyre I have tried. Ice skates would be grippier than them in the wet.
RE001 doesnt seem to last to long. I have GT Radial Champiro HPX, they are a very good tyre
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby 1I1 » Mon May 03, 2010 10:36 am
Also found that the grip isn't all the best in the wet with the RE001's, infact my 20v was able to spin a wheel in 3rd gear 8O
In the dry the are all good though
Don't get me started on MY-01's
TRD Clicky >>Here
1I1
Postby sergei » Mon May 03, 2010 10:46 am
I have done ~25k so far on RE001 and have ~ 4mm thread left. I expect it to last ~35-40k, which is ok.
Postby B_giB » Mon May 03, 2010 11:19 am
sergei wrote:I have done ~25k so far on RE001 and have ~ 4mm thread left. I expect it to last ~35-40k, which is ok.
That is very strange, most I have heard out of RE001's.
My father only got 30,000 km out of his in his outback
B_giB
Postby sergei » Mon May 03, 2010 11:33 am
Well, I rotate them every 5k, and run them at 40psi.
Postby 1I1 » Mon May 03, 2010 12:00 pm
Is that what they are meant to be run at, 40psi?
TRD Clicky >>Here
1I1
Postby sergei » Mon May 03, 2010 12:21 pm
1I1 wrote:Is that what they are meant to be run at, 40psi?
I find them best at 40psi. Especially in the wet. Also they wear out evenly at that pressure.
Postby tsoob » Mon May 03, 2010 12:28 pm
depending on the size, but if you are on a 45/40/35 series you need them pretty hard
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby 1I1 » Mon May 03, 2010 1:01 pm
I'm running 205/40R17 at 32psi... might bump the pressure up a bit then!
TRD Clicky >>Here
1I1
Postby tsoob » Mon May 03, 2010 1:02 pm
1I1 wrote:I'm running 205/40R17 at 32psi... might bump the pressure up a bit then!
what tyres are they? id say 38-40 min press
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Boosted_162 » Mon May 03, 2010 1:14 pm
I run my 215/40/17 at 40psi. Its what tyrecorp recommended as well. I get even wear and they seem to be lasting well.
Postby 1I1 » Mon May 03, 2010 2:02 pm
RE001's :wink: Will pump them up at some stage
TRD Clicky >>Here
1I1
Postby Bling » Mon May 03, 2010 2:10 pm
36-38psi here on 205/40/17s
German F1s
40 Is too bumpy imo :lol:
Postby Boosted_162 » Mon May 03, 2010 3:34 pm
BZG|Bling wrote:36-38psi here on 205/40/17s
German F1s
My suspension is so firm a few psi doesnt make a difference at all :lol:
Postby B_giB » Mon May 03, 2010 4:01 pm
He did the same, still low kms
B_giB
Postby Bling » Mon May 03, 2010 5:13 pm
Wait so 30,000km on a 4wd (i'm guessing here) you consider to be low mileage?
I'd be happy with that mileage, though I don't nana it so happily forgo some mileage for some spirited driving :twisted: tbh I would rather go tyres before they go hard from years in the sun than have them last longer but lose their performance. Which is what i'd imagine would happen.
Postby rolla_fxgt » Mon May 03, 2010 7:13 pm
1I1 wrote:Also found that the grip isn't all the best in the wet with the RE001's, infact my 20v was able to spin a wheel in 3rd gear 8O
Exactly what i've experienced. Must be all the torque the 20v's create :lol:
rolla_fxgt
Postby sergei » Mon May 03, 2010 9:08 pm
Hmm, I found it good in the wet, they are on my ST205 GT4, 225/50/16.
Postby Snoozin » Mon May 03, 2010 9:09 pm
Likewise, I ran them at a VERY wet trackday at Taupo and wet grip was pretty impressive...
Snoozin
Postby Boosted_162 » Mon May 03, 2010 9:13 pm
Ive found exactly the same, must have to do with weight (more lack of), the heavier cars seem to be fine in the wet, while the light ones suffer.
