iOnic wrote:sergei wrote:Reducing back pressure should theoretically reduce the boost as it is reducing the restriction.
nuff said
iOnic wrote:That's a topic of people telling you they have no problems with their ct20b's and free exhaust systems......
It's pretty clear from that discussion that your problems are/were isolated to you/your carDon't automatically assume ALL upgraded exhaust systems are bad simply because you used a cheap and nasty downpipe that is known for causing that exact problem
(seriously what were you expecting) and had trouble with it...I have designed several different exhausts/downpipes for ct26/20b turbos on my and other cars and have never had that problem. Besides, if the stock exhaust is as good as you say it is - why'd you upgrade it?
nuff said
sergei wrote:The waste gate is pressure activated. So any decrease or increase of restriction would cause the wastegate to compensate.
I know for a fact that a lot of stock wastegates are in fact barely enough, hence there are boost spikes even on stock vehicle.
Look at this way, why the boost would climb to over a bar and drop on higher rpms to a steady 0.8bar on ST205?
Or I've seen subarus spike up to 1.5bars and then hold steady at 1.2bars (although this might be to ECU trickery to gain more torque, because they have a proper boost control unlike ST205).
Also my new wastegate setup on ST165 is holding steady any boost from 0.5bar and up (whatever I set it to on EBC), be that sudden full throttle on 5000rpm or steady build up of rmps from 3000rpm under load.
cat007 wrote:sergei wrote:The waste gate is pressure activated. So any decrease or increase of restriction would cause the wastegate to compensate.
Except you're forgetting that an engine is purely a pump - the faster the air can get in/out the better
The turbo is already doing the in part, the 'bigger' exhaust helps with the out....
sergei wrote:The only "improvement" that you will get from 3" no restriction, no cat, on the the stock turbo is over-boosting (uncontrolled, beyond 2 bars).
sergei wrote:My point is the boost spikes are only there because wastegate system is not sufficient.
iOnic wrote:sergei wrote:The only "improvement" that you will get from 3" no restriction, no cat, on the the stock turbo is over-boosting (uncontrolled, beyond 2 bars).sergei wrote:My point is the boost spikes are only there because wastegate system is not sufficient.
Sort out your contradictions please. First the boost spikes were only there because the exhaust was less restrictive and now it's the wastegate system?
And yes......in it's simplest form, an internal combustion engine is, in effect......a pump. A complicated pump but a pump nonetheless....
sergei wrote:What is contradicting there please?
You basically do not understand what causing over boost.
Here simple explanation:
The gas flow "prefers" going through turbine than wastegate system with larger pressure difference between the turbine housing and turbine exit. As the exhaust more restrictive the flow goes through wastegate more than with less restrictive exhaust.
As simple as that.
Lith wrote:sergei wrote:What is contradicting there please?
As simple as that.
That would have to assume that the wastegate was venting externally, right?
