OllieS wrote:DRS is rubbish (at the moment, doesn't work as intended) and how about RB not even using KERS!
OllieS wrote:Thems the breaks. Button got flustered and stuffed up and Ferrari capitalised. Genius move telling Massa to let Alonso pass as well straight afterwards, would have led to a two easy overtakes had Jenson let them past straight away. As it happened he held out and got the drive through penalty.
Will be interesting (but ultimately irrelevant) to see if Button did have his nose in front at the corner. I'm sure it will be hotly debated by the fans on either side.
By the way, for proof of the engineering awesomeness behind the RB front wing, check out the following pics. I think its awesome that they introduced a load test to stop this but the engineers just design the laminate to pass the load test, but still flex under the aero load. Definitely some heavy calculations behind that wing.
Sideros wrote:Anyone that thinks button was past massa is clearly wrong. That's all there is to it.
