Postby Grrrrrrr! » Fri May 31, 2013 7:18 pm
Compression tested it... 4 @ 195-200 psi = me happy.
Also drove it for first time in ages.. I need to do more of that!
Grrrrrrr!
Postby Stott69 » Sun Jun 02, 2013 9:17 pm
Can you mount a exhaust flexi on a slight bend?
Stott69
Postby Quint » Mon Jun 03, 2013 11:48 am
don't see why not. tighter the bend, the more it'll 'collapse' and reduce x sectional area tho.
Quint
Postby touge_ae101 » Mon Jun 03, 2013 1:04 pm
they wear out REAL fast when mounted on a slight bend. was replacing my flexi every 2 months of daily driving when mine was mounted on an angle..
touge_ae101
Postby Stott69 » Mon Jun 03, 2013 11:08 pm
Measured it and its 45° so its not a slight kink
Stott69
Postby Adoom » Mon Jun 03, 2013 11:13 pm
Thought about taking it for a thrash. Last WOF ran out in March....Just before I started the last lot of modifying and tuning. Decided that if there was a chance I was going to get pulled over for speeding, I should have a WOF.... :roll:
Adoom
Postby Dell'Orto » Mon Jun 03, 2013 11:14 pm
Especially with a 4km/h tolerance!
Open the door on the sedan to show some friends what it looks like these days. Bout the limit of my car work lately :?
Postby malc » Mon Jun 03, 2013 11:28 pm
Painted up a new front lip over the weekend and put it on today :D.
Wanted one since I got the car 7 years ago, finishes it off nicely.
IMG_4591 3 by timhnz, on Flickr
IMG_4594 by timhnz, on Flickr
malc
Postby duddley » Tue Jun 11, 2013 4:22 pm
New front brake rotors and pads, parts are so pretty when they are shiney and new.
i don't club seals..... only sandwiches
duddley
Postby Stott69 » Fri Jun 21, 2013 9:47 pm
Is it a bad idea to start a car with half the intercooler pipe missing and only a dump pipe?
Stott69
Postby Lloyd » Fri Jun 21, 2013 9:50 pm
If oil lines are all plumbed up and it has a throttle that can close then go for gold
Postby 1I1 » Sat Jun 22, 2013 5:29 pm
Sunday last weekend: replaced front pads
Tuesday: swapped over bootlid with one that has no spoiler (dont like the look of pulling a spoiler off and leaving holes)
Today: Played in the rain at Manfeild. Kept it on the blackstuff and did a 1:32.1. So allowing for roughly 4 or 5 seconds difference between dry and wet puts me in the 27-28 range in the dry :D
TRD Clicky >>Here
1I1
Postby DeeCee » Sat Jun 22, 2013 9:34 pm
Last 3 days, dropped subframe, removed prop shaft, exhaust, fuel/brake lines and fuel tank in prep for paint. Friend came around today and started to remove all the clips and loom at the rear of the car as well. About to clean up garage a little before we take out the interior.
Then its finishing up some work on the firewall engine loom connector mounting, remove glass and winder mechanisms from doors and get engine in again to measure for custom wheel spacers. Drill some holes to mount cold air intake flange and maybe mockup base of cold air box to see if I have to drill anything else in the bay.
Then remove engine, wet sand 400grit to prep for paint.
Also need to build wide body guards at the front and make some moulds of guards, bonnet and bumper.. RC parts are $$ to replace and I want some moulds in case something goes wrong when car goes back on road.
GT Four Adovansu
DeeCee
Postby MrOizo » Sat Jun 22, 2013 11:31 pm
Put intake manifold back on. Maybe not ready for my Hypertune dreams just yet. I just want my car going!
Intercooler showed up last week which was nice. Just need some decent time to install it. Plenty more joiners needed to hook it all up.
MrOizo
Toyspeed Legend
Postby Distrb » Tue Jun 25, 2013 12:29 pm
Drove it through the fog as fast as possible
Distrb
Regular Poster
Postby Adoom » Tue Jun 25, 2013 2:52 pm
Got a WOF for THE STARVIA on the way to work. Drove to Lower Hutt in the terrible because-no-trains traffic. Clutch leg got a work out.
Took it home at lunch to swap for my motorbike so I don't have to do the same thing on the way home after work.
Turned on all the boost and E85 for 173KW. :D
Every time I passed someone, I could not help but giggle like a school girl as I broke traction(the road is damp) and suddenly found myself in loss-of-licence territory.
I tried REALLY HARD to restrain myself and managed to keep it under 150kph 8O :oops:
CAN'T WAIT FOR TRACK DAY!!!!!!!! :D :D :D
Adoom
Postby ~SlideWays~ » Tue Jun 25, 2013 3:48 pm
On your long private driveway.
Not sure why there are other cars to pass on your long private driveway though. :lol:
~SlideWays~
Postby Burning Angel » Tue Jun 25, 2013 7:16 pm
Started dissasembling the Starlet for a rebuild on many aspects that in retrospect were rough as $&#$%.
When I built the car I had no engineering experience, now that I do I see heaps of stuff I don't like and want to fix up
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Stott69 » Tue Jun 25, 2013 7:44 pm
Funny, I find heaps of that stuff on mine, but dont know how to fix properly yet.
Ordered stuff to finish Intake, so current date of 3 weeks til legal looks promising
Stott69
Postby the fallen303 » Tue Jun 25, 2013 7:59 pm
finally did oil change on the aristo a few weeks back. it was pretty yuck. we did it a bit odd though. to change the oil we unbolted everything off the front of the car to give us more room, and the aircon/fan etc from the passengers foot well. we then removed the engine and sat it on the ground along with trans, driveshaft and diff. we then changed the filter. before we put fresh oil in it we put the engine into the new aristo shell along with trans, etc. redid the needed bits, then filled it with oil.
not bad for an afternoons work...
true house of JZ
Stay true to the origin
the fallen303
