Postby Bling » Sat Feb 22, 2014 1:59 pm
Got myself some new boot seal rubber from Para Rubber (25% off this weekend FYI) and some wax from SCA, 2 for $15 not bad. Now to actually wax it.
Postby 2jayzgte » Sun Feb 23, 2014 5:31 pm
While my rotors were getting changed one of the mechanics showed me how one of there other clients had a slight mishap at Bathurst down Conrod straight at 200 +kph.
http://www.youtube.com/watch?v=c__74bgZuFQ
2jayzgte
Postby CAMB01 » Sun Feb 23, 2014 9:51 pm
oooo ouch
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby steroidcontaskie » Mon Feb 24, 2014 2:36 pm
Got a another engine for my soarer. Now get head studs etc....
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby matt dunn » Mon Feb 24, 2014 11:34 pm
Put the rear bumper etc back on it after getting it back from some paint and panel repairs.
Load it on the trailer tomorrow to go off to the signwriters to get it all put back on again.
Postby ~SlideWays~ » Tue Feb 25, 2014 11:04 am
Pulled donor FXGT to bits:
~SlideWays~
Postby duddley » Wed Feb 26, 2014 1:58 pm
Got a new annual WOF for the Vitz.
i don't club seals..... only sandwiches
duddley
Postby matt dunn » Fri Feb 28, 2014 9:19 pm
Bought a new shiftlight off trademe,
been waiting for almost a year for a specific one to come up for sale on trademe second hand.
The Ecliptech Shift=i progressive shift light.
Postby 85AW20v » Fri Feb 28, 2014 11:53 pm
matt dunn wrote:Bought a new shiftlight off trademe,
All sorts of features on them too that you can play with. Nice and bright no matter what the weather as they brighten up in the sunlight and dull down at night automatically - not that the night feature would bother you Matt!!
Converted the BT C56 gearbox to AW linkage. Took about 2 minutes with a cutting disc and angle grinder.
See ya
Simon
85 MR2 20v
85AW20v
Postby iOnic » Sat Mar 01, 2014 10:08 am
Dragged it out of the dark corner of the workshop and changed the rotors and pads. Probably gonna change to different pads soon. These don't really work when cold.
Postby Alex B » Sat Mar 01, 2014 2:39 pm
^ What are you using? Need to do mine soon, was just going to try genuine Mazda ones.
Postby iOnic » Sat Mar 01, 2014 6:12 pm
DBA discs and hawk hp+ pads from mpsgarage.com.au. Genuine is dusty and inconsistent. I'd go Hawk HPS I think
Postby sergei » Sat Mar 01, 2014 9:29 pm
Fitted starter and injector resistor pack.
Started it for first time (first time for this engine). It runs!!! $&#$% loud without downpipe or wastegates.
started assembling down pipe, found out that due to different turbo position between ST165 and ST205 down pipe does not match up to the rest of the exhaust (off by about 3-4cm).
Then proceeded putting on external wastegates, which due to larger ST205 exhaust manifold no longer fit (one of the waste gates interferes with exhaust manifold)..
Damn. :(
These problems I cannot fix myself (due to lack of skill and welder equipment).
So I will need to tow the car to someone who can extend one of the waste gate pipes and realign the exhaust to the downpipe...
Once I resolve this issue, next step will be addressing hubs (pressing in and out bearings again) as ST202 hubs are definitely not equal to ST165 (they looked the same, should have measured them :(). Then I will need to find a better radiator for the intercooler...
I will also have to talk to Barry regarding his suspension kits, but that is after I address the wastegate issue...
Here are the photos:
Postby Boosted_162 » Sun Mar 02, 2014 12:25 pm
Slowly getting there!
Theres no suspension in the front, and the back will go lower
Postby Grrrrrrr! » Sun Mar 02, 2014 8:37 pm
Bought a laptop, installed the link and had a nosey at the last tune (so much for seller saying it'd never been used). Time to build the motor and get it tuned.
Grrrrrrr!
Postby siren676 » Sun Mar 02, 2014 8:55 pm
Went to Pukekohe to take some pics at a track day but ended up putting my car on the track instead :lol:
Few things I've taken away from the day is that the Starlet is very tail happy, i need a bigger radiator, need better tyres and to finally get it tuned properly
siren676
Postby 85AW20v » Sun Mar 02, 2014 10:36 pm
Changed the linkage on the C56 to suit the AW. About 2 minutes with the angle grinder did it.
Cut up the OEM seal and glued it in place.
Also fitted my TRD LSD into the C56. All torqued up and saw the gearbox magnet sitting on the floor. It had fallen out when I split the box and I didn't notice it sitting there. Contemplating just leaving it where it landed seeing as it's not a road car and doesn't do a lot of km's. If it is going to go bang on the track, I suspect the magnet won't help much.
See ya
Simon
85 MR2 20v
85AW20v
Postby wde_bdy » Tue Mar 04, 2014 12:38 pm
New extractors arrived today, courtesy of Rush Automotive. Should help the 7K breath a little easier. 8)
Callum
wde_bdy
Postby Grrrrrrr! » Thu Mar 06, 2014 1:06 am
Took it to bent sprints at Puke, got thrashed, had some fun, took out some cones. Had a couple of high pucker factor moments when the current suspension setup got a bit unsettled by some of the bumps at turns 9 & 10. Upgrades required.
Grrrrrrr!
Postby Grrrrrrr! » Thu Mar 06, 2014 7:23 pm
Decided to give this driving in a straight line form of racing of go, so stuck the race numbers I picked up the other night on the quarter windows, threw an offcut of wood under the battery to help secure it properly and texted a mate to make sure I had another similar (ie slow) car to do some grudge matches with.
Grrrrrrr!
