ae101 levin factory amp?
Postby levinguy » Mon Jan 09, 2006 11:00 pm
theres a box under the seat of my 92 levin gt apex theres two sets of wires going to it and the code um-218 on it and toyota and fujitsu stickers all the writing except for thats in jap
is it a factory amp or wat?
i'v tryed searching UM-218 but it comes up with nothing
levinguy
Postby KinLoud » Tue Jan 10, 2006 1:36 pm
Box under passenger seat?
It's an amp that only works with the factory headunit.
If you have an aftermarket headunit you can remove the amp.
If you do have the factory headunit and it works... you are lucky!
Lucky that the amp hasn't blown up yet! (some components on the circuit board fail and turn into small lumps of charcoal).
Sadly the amps aren't very reliable now that they are more than 10 years old. Very difficult to find another factory amp that works (been there done that!).
Ken
Ham
021 408 863
Postby sergei » Tue Jan 10, 2006 4:50 pm
I've made it working with aftermarket head unit with RCAs outputs (also possible to use the speaker outputs)... I've hacked into amp loom and found the shielded line inputs and remote (line inputs are same colour code as speaker wires, but they are much thinner)... the only reason why I used it at that time because the amp in head unit was fried... it is not bad as amp but powerwise is about the same as internal amp in average head unit.
Postby rallyrulz » Wed Jan 11, 2006 5:36 pm
There is an amp and some noise filter box thing under there. The noise filter is only there because its a cheap and shitty amp. When I took my car to get its new head unit put in, they had to re wire it to bypass the amp. An aftermarket head unit is at say around 45W per channel and does not need that amp any more, it was only there to power the again crappy factory head unit which probably made around 5W per channel.
Anyway ken... what you doing playing with that old amp in my car... Well the car now has a new head unit, new brakes, some tints, some tlc and run perfectly, hope your race car is going well.
rallyrulz
Postby Low_Aa63 » Wed Jan 11, 2006 6:57 pm
could be wrong but arent they pre-amps?
Just tiny amps ussually 33 by 2 channel amps because the factory head units are so retarded that they need to have the sound level beefed up a bit! also a security measure as far as i was aware.. ie if you steal the factory head unit and fail to take the pre amps, when you wire it into another car it detonates a small thermo nuclear charge and kills anything in a 2kilometre radius....
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby KinLoud » Wed Jan 11, 2006 7:03 pm
Hi - yeah I must have tracked down about 4 factory amps when I used to own your GTZ. I think 2 of them worked for a couple of months and then blew up... fixed one (replaced the capacitors) but something else died in it...
Just worked out where the pic of your car came from :) I remember taking it, got up early on a cold Taupo morning to catch some of the sunrise, cool.
I'm glad it went to a good home.
Racecar is good, now has a 3sge gen3 in it!
Ken
Ham
021 408 863
Postby Alex B » Wed Jan 11, 2006 7:44 pm
After market headunits are about 22x4 max, havnt seen much higher than that except maybe the P1Y, even thats only about 27x4.
Postby Dell'Orto » Wed Jan 11, 2006 11:07 pm
pyro_sniper2002 wrote:After market headunits are about 22x4 max, havnt seen much higher than that except maybe the P1Y, even thats only about 27x4.
Eh? Quoted figures are 50-52w per channel max, 60w for the P1Y...you're talking RMS values there.
Postby Alex B » Thu Jan 12, 2006 12:46 am
yea sorry i was talking rms [the figures that accualy mean something other than wank factor] :P
