Any way ive heard they are a bit expensive on the maintance side of things and prone to leaking head gaskets.... etc
I asked my mechanic about them and he reccomended to stay away.
so any one had one before? Should i go for it or stay away..
'The Wombat wrote:now from the welly toyspeeder who own's one.
Yes the cost hurts but if you do what i've done and look around and do your reserch you can build it up strong.
the reason i have not been going down to the welly meets is i've just spent 3k doing a full engine rebuild (befor i blew it up) and strengthing. which has been...
1.Full replacment of all the engine gaskets with steel lamited kits and replacment of seals and rings. and re-seating of the valves and piston sets. aka full rebuild
2.full port and polish
3.pressure test of the block
4. high flow thermostat and water pump and new lines
5. A/c removed and new larger front mount installed (a/c line were damaged)
6.new bov
7.new boost controller
8.battery to the boot
9. custom air intake
10. full dyno tune (results to be found out)
11. reprogranmed EMS
befor i had done any of the work the car was like sh*t of a stick crazy fast nd i can't wait to get it back.
next on the list is .
1. new box to build up (found one but at $1270 i might have to wait a bit)
2.new suspension set up
3. new ehaust system set up 3inch all the way thru and new dump pipe with waste gate
4.600cc injectors
at the end of the days all cars have problems at some stage with some things .
