A morning at the dyno...
Postby GT4 20 » Tue Feb 14, 2006 3:04 pm
Following the arrival of the Apexi Power FC last Friday, it was 'installed' on Sunday and today was the day it was properly mapped.
While it did have base maps already 'on board' and the car was driveable, it certainly wasn't as good as the OE ECU - it did smooth out a couple of flat spots on trailing throttle, but it obviously wasn't good enough to be driven on for any period of time.
This was immediately blatant on the dyno when at cruising revs, the ignition was being advanced to +50 degrees 8O And that is not a typo.
Anyway, a couple of hours later and the engine was running very sweetly indeed and was producing some decent figures. I'm still essentially running the motor in and as such, am keeping the boost down for another 3000ks just to make sure.
Two boost settings have been set by the Profec B - 13.6psi and 10.5psi.
Here is the 'High' setting...
Pretty happy with that. Only 8kW lower than the previous dyno before the work was done and running 16.2psi.
The lower setting showed 164.3kW - again with a beautifully flat torque curve. This chart has been overlaid with a mate's ST205 readout who is running an Apexi Power FC, high flow CT20B, full exhaust and K&N panel filter...
An obvious difference in power delivery - especially at the top end of the rev range. Other engine is running out of puff below 6000 while mine is still pulling like a schoolboy at 7200 with a higher boost setting. A testimony to the HKS 264 cams and fully worked cylinder head. Things can only improve with a bigger turbo, exhaust and tubular exhaust manifold.
Have to say I'm a happy chappy :D
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby 86_rolla » Tue Feb 14, 2006 3:14 pm
i have absoloutly no idea what any of that stuff means but it sounds good :oops:
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby Ako » Tue Feb 14, 2006 3:23 pm
That suckers gonna absolutely thrive on more air being thrown at it, have fun!
cough*GT3040R*cough 8)
Ako
Postby Leon » Tue Feb 14, 2006 3:35 pm
So, exactly how many competition cars are you building then? :wink:
Postby GT4 20 » Tue Feb 14, 2006 3:40 pm
Leon wrote:So, exactly how many competition cars are you building then? :wink:
Just the one. This is my daily drive :P
Gary
GT4 20
Postby Pies » Tue Feb 14, 2006 3:49 pm
*coff*wanker*coff*
:P
Current Rides:
Pies
Postby Akane » Wed Feb 15, 2006 1:08 am
The PowerFC's 50 degrees advance is normal while crusing / high vaccume. And you should pick up a few more hp over the OE ECU due to it's more agressive fuelining and timing settings.
Since money is (almost) no object to you (with that expensive build of yours), you should've dyno'd with the OE ECU back-to-back with the PFC.
Postby GT4 20 » Wed Feb 15, 2006 7:40 am
It's not a case of 'money being no object', just that if I do something, I want to do it right first time. It tends to get expensive if you cut corners and end up blowing the engine.
Gary
GT4 20
Postby RomanV » Wed Feb 15, 2006 9:07 am
GT4 20 wrote:It's not a case of 'money being no object', just that if I do something, I want to do it right first time. It tends to get expensive if you cut corners and end up blowing the engine.
Gary
Quoted, just so people read it twice.
Postby fivebob » Wed Feb 15, 2006 10:24 am
Gary
Won't do much good, I've been saying the same thing for years. Some people will always try and go the "cheap" route, which ends up as the more expensive alternative almost every time :roll:
Postby RomanV » Wed Feb 15, 2006 10:35 am
Although, I suppose I'm not one to talk anyway.
I reassembled my engine myself, and time will tell if it is going to blow itself up as a result. :lol:
Postby Akane » Wed Feb 15, 2006 11:27 am
I just wanna see what the gains are, nothing to do with cutting corners, and I know Gary is "bling bling", I want his DSLR camera! Pity no good night scenes in NZ for me to shoot it with tho even if do own one of those badboys.
Postby GT4 20 » Wed Feb 15, 2006 1:03 pm
Akane wrote: I know Gary is "bling bling",.
I'd hardly call myself "bling bling" 8O There is a difference between using decent stuff and things that are just for bragging rights :wink:
Gary
GT4 20
Postby Mr Revhead » Wed Feb 15, 2006 2:40 pm
you mean like TRD oil caps? :P
nice figures, cant wait till you get the turbo etc done and its all complete.
then you owe me a ride in it :D
Users browsing this forum: Bing [Bot] and 14 guests
