v8 conversion on crown
Postby saundersjf » Sat Apr 01, 2006 12:07 pm
i have a ms65 sedan..
im thinking dropping a v8 into it (quad cam/350 etc)
just woundering would my diff handle it .. its a standard 4m diff ratio 3.9 70 series???
info would be great thanks
saundersjf
Postby Mr XXX » Sat Apr 01, 2006 6:56 pm
yay, for f series diffs, my buddy is running 1jz turbo in his ms65, has gone through one diff head from doing burnouts etc... maybe upgrade to g series would be best
Allan
Seedy Al's Chop Shop
Current Rides - 7-age At141 Corona, 81 kE70 Sedan, 1970 MS55 Crown, 72 B1600, ke25 Corolla x 2, Suzuki Carry Van x2, 910 BLuebird, 4age KP starlet
My Life Is a F*cken Project
Suck a Dx Chris
Mr XXX
Postby Truenotch » Sat Apr 01, 2006 7:42 pm
Apparently a 1uzfe wont fit in the ms65 engine bay so make sure you measure.
Truenotch
Postby evil_si » Sat Apr 01, 2006 9:50 pm
Truenotch wrote:Apparently a 1uzfe wont fit in the ms65 engine bay so make sure you measure.
i had a customer want to put a 1uzfe into a 72 corona /crown i cant remember and i dont know the model,
but from a few quick measurements it would be a very tight squeeze, a lot of cutting required, firewall, cross member and inner guards
evil_si
crown
Postby saundersjf » Sun Apr 02, 2006 1:37 pm
oh cheers um what are the g series out of??
and u saw it won't fit on the ms65 the iner guards can be fully taken out.. and you could staddle the straight six thats in it now, and close the hood.
apparently in their day the 258(?) chev small block was the most common conversion..
the 7m-gte bolts straight on, but does the 7m-gte box fit in with out changing the sharft??
saundersjf
hmm
Postby ezy10s » Sun Apr 02, 2006 2:31 pm
centre bowl 1uzfe will fit- only thing is the right side header will get extremely close(if not touching) to the steering box. length and height isnt an issue.
Member #244
ezy10s
crown
Postby saundersjf » Sun Apr 02, 2006 9:00 pm
ohh i c
well im glad im finding out all this now.
saundersjf
Postby Mr XXX » Sun Apr 02, 2006 10:12 pm
g series is hilux.
m series motor is poo
Allan
Suck a Dx Chris
Mr XXX
Postby FLAWLES » Mon Apr 03, 2006 8:25 pm
nah 4ms are great what are you talkin bout lol
in my ms55 crown we measurred up a 1uz it would fit perfectly the only thing you have to do is change the brake booster " providing that the crown has one or is running a remote booster "
if so just slap a vh65 of 55 cant remember bosster and all will be fine
give me till december i should " should " have a 1uz in mine
FLAWLES
Postby Gx71man » Tue Apr 04, 2006 10:59 pm
Mr XXX wrote:g series is hilux.
Allan
This man speaks the truth... F series should be allright, depends how you treat it. Im gunna run one (or try) 200-300kw atw's.
My mates dad just fully overhauld one, fark it is sooo straight.
I Give My Mrs A 1/4 inch at a time, For those ten seconds or less Im Free...
Gx71man
Users browsing this forum: No registered users and 27 guests
