cheap i/c joiners
cheap i/c joiners
Postby SpeedRacer » Fri Jun 02, 2006 5:41 pm
not impressed with a quote i recieved today for $90 for a 45 deg silicon joiner. So was wondering if anyon here knows where to get cheap rubber or silicon joiners?
Looking or 8 or 9 of them (couple of 90's, 45s, straight and a reducer)
2.25" or 2.5"
Sinister Sleeper 35
SpeedRacer
Postby sergei » Fri Jun 02, 2006 5:45 pm
what you could do is to buy alloy bends from Ulrich Aluminium, and just use straight joiners, this way it will work out way cheaper. We actually managed with 1 180 degree alloy bend and some rubber hose for joining on my mates cynos. (and 1 silicone joint, as we run out rubber stuff). You could buy some 'radiator hose' at 121 Marine, it is really tough and does not colapse. Although rubber joiners are not very pretty.
Postby SpeedRacer » Fri Jun 02, 2006 5:48 pm
sweet will go hav a look.
id care about pretty if it made u go faster :wink:
Sinister Sleeper 35
SpeedRacer
Postby evil_si » Fri Jun 02, 2006 5:51 pm
there are better places than ullrich, such as tube bending in east tamaki
evil_si
Postby sergei » Fri Jun 02, 2006 5:51 pm
do they do alloy bends?
Postby edwagon » Fri Jun 02, 2006 7:03 pm
Not quite what you're asking, but good to know anyway...
for the hose itself you can use marine radiator hose, much cheaper than silicone. It doesn't balloon under boost either, but prob best to keep it's use to joiners where the gap is minimal, rather than for long sections.
I get mine from 121 marine on the shore, but anywhere similar should be able to look after you.
edwagon
Postby trueno_20v » Fri Jun 02, 2006 8:58 pm
i can get you the same as mine, they are rubber, lightish blue or black , i think i can only get 2.8" straight, 2.8" 90 degree, and 3"-2.8" reducer, will have to see about 45degree, they easily clamp down to 2.5" as ive used them all for my piping and are sweet as, i can get them for approx $13 ech, pm me if you want me to get you some and couier them to you.
ADMIN EDIT: signature too large
trueno_20v
Postby aesc » Fri Jun 02, 2006 10:49 pm
Try STA parts www.staparts.co.nz , they have cheapish silicone bends, and there are sellers on TM wanting around $40-50 ea, just a matter of searching
EX AE101 owner
2013 Ford Focus ST
aesc
Postby bluemaumau » Sat Jun 03, 2006 12:41 am
on my mates charde he needed about a 30 cm strait, he payed 10 buks for 30cm of boat fuel line. it worked a treat 8)
Postby THA SHZ » Sat Jun 03, 2006 12:52 am
Try pm'ing al (TWSTD) on the forums , as he does silicone bends at a good price and they are top quality , and hes a toyspeed sponser , cant go wrng there 8)
THA SHZ
Postby RS13 » Sat Jun 03, 2006 12:53 pm
Or failing that, go to a plumbing supplies store, and ask for "plumbers' quick". Its' a rubber hose thats' cheap as, I've never personally used it, but I know people who have. I'd recommend this only as a last resort though!
RS13
Postby Caveman » Sun Jun 04, 2006 11:57 am
Most engineering suppliers sell cheap joiners.
They are the factory style, two layers of reinforcement. Samco, HTS, etc are silicone and have around 3/4 layers of reinforcement.
They sell 2' for $3.20 and 2.5' for just over $4.00. They are rated to 60PSI. They come in 100mm lengths
With that you can buy a steel bend and clamp it using the joiners.
AW11 Track Toy
Formerly known as 1998
Caveman
