Why to not run too much boost on bluetops with stock ecus
Postby crnkin » Wed Jul 19, 2006 6:15 pm
The worst piston, with a link it would be much better, this was with 13psi on 265cc injectors in diag mode
too much heat.
Just thought id show this to people wanting to run the set up, be careful.
Note, this engine did have 300,km's before beginning.
deaf_homo "currrently yes"
crnkin
Postby l1ttle_d3vil » Wed Jul 19, 2006 6:17 pm
would the extra 5psi make all that difference? (as opposed to running 8psi)
Postby crnkin » Wed Jul 19, 2006 6:23 pm
yes. Stick with stock actuator until you get a link
crnkin
Postby mr pad » Wed Jul 19, 2006 6:25 pm
So the engine was 300,000kms old?
mr pad
Postby crnkin » Wed Jul 19, 2006 6:37 pm
ah yes
crnkin
Postby mr pad » Wed Jul 19, 2006 6:38 pm
hahaha awsome.
mr pad
