Fuel Economy, Vac Vs Rpm
Postby CozmoNz » Sun Sep 10, 2006 7:13 pm
Ive always wondered, even though its a fairly pointless thing to wonder (but gives people something to read / reply to for the time, until we all die).
Your cruising along, in say 3rd gear, 50kph, 3300rpm, at around -15 vac....
holding just fine... whats better for fuel economy, the above, or changing to forth, say 2400rpm, -10 vac... :).
Less throttle, more rpm... more throttle, less rpm....
Since vac basically means more airflow (less vac).... and more air = more fuel? yah? but more rpm = more air... so uhh, cozmo confused :(.
Rayne For President!
CozmoNz
Postby Quint » Sun Sep 10, 2006 7:18 pm
I've often thought about that.... Yea, i can't help you :)
Quint
Postby fangsport » Sun Sep 10, 2006 7:30 pm
didn't the XD,XE falcons have an economy gauge, that was essentially a vacuum guage?
fangsport
Postby Lloyd » Sun Sep 10, 2006 7:43 pm
And some Commodores I though, and a heap of BMWs
Postby Dirtbag » Sun Sep 10, 2006 8:22 pm
Lotsa mercs had them aswell, and yea, i have always thought about that question, i would think its less revs, but could be wrong
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby bluemaumau » Sun Sep 10, 2006 9:41 pm
i always thought -10 was good
Postby fuel » Mon Sep 11, 2006 12:17 am
Yes I've always thought about that too.
I would rather the engine to be under less load (ie -15 vac) and do higher revs rather than vice versa. Just because the engine is doing higher revs, doesn't mean more fuel is being injected. Think of a car engine braking or on overun at high rpm with throttle shut - it's under high vacuum and little to no fuel is being used.
LOUD NOISES!!!
fuel
Postby Dirtbag » Mon Sep 11, 2006 2:31 am
im damn sure ive read in a 16v manual or something that without the throttle on fuel is only returned once the revs get below 1400rpm. Eg engine braking there would be no fuel flow till the revs dropped right down...
My profile!
Dirtbag
Postby Akane » Mon Sep 11, 2006 4:44 am
I have seen a certain "modern" engine's "fuel efficiency" graph to maintain constant cruise speed, the sweet spot was around 2.5k~3.3k rpm, then it's a x^2 (well not that steep) graph as the RPM rises.
hth.
Postby Dirtbag » Mon Sep 11, 2006 5:01 am
so with most "sports" cars that would mean around 4th gear up to 70ish or even sometimes higher? I know im doing 2000rpm at about 65ish in my ae101 in 5th.
My profile!
Dirtbag
Postby slighty_sykotic » Mon Sep 11, 2006 9:53 am
I know the answer to this... I just have to remember....
Driving with my laptop hooked into the link so I can see the injector duty cycle. Now, i just can't remember which way around it was :cry:
In 3rd gear it was 4% duty cycle at 50, and dropping into 4th was 3% duty cycle at 50km.....
I think.... Pretty sure it was around that way (not the other).
in a 4agte in a ae101 with a c52
--Sykotic
slighty_sykotic
Re: Fuel Economy, Vac Vs Rpm
Postby Stealer Of Souls » Mon Sep 11, 2006 10:38 am
CozmoNz wrote:Ive always wondered, even though its a fairly pointless thing to wonder (but gives people something to read / reply to for the time, until we all die).
I would have thought that fourth was better.
I think that in third or fourth at a constant speed the required power output of the engine should be the same (???), or at least pretty close to it. So if the power output is the same then the relative fuel consumption should be the same. Except that at a lower rpm each cylinder is filling more completely to produce the same output. The change in vac could be because of that couldn't it? Also at lower rpm there are probably lower losses (pumping, pressure drops) in the engine. So slightly more efficient, and therefore lower fuel use...
'86 AE85.5 Levin
Stealer Of Souls
Postby ee904age » Mon Sep 11, 2006 7:04 pm
I read in an AA mag a while ago that most engines are most economical at the point of highest torque. True or Not True....who knows?
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Stealer Of Souls » Tue Sep 12, 2006 9:38 am
ee904age wrote:I read in an AA mag a while ago that most engines are most economical at the point of highest torque. True or Not True....who knows?
I think I read that they are most efficient at peak torque. Not economical... Could be wrong though...
'86 AE85.5 Levin
Stealer Of Souls
Postby strx7 » Tue Sep 12, 2006 11:25 am
injector duty cycle x engine rpm will give you a number to go by for comparisons
Postby Akane » Tue Sep 12, 2006 1:16 pm
strx7 wrote:injector duty cycle x engine rpm will give you a number to go by for comparisons
Is it safe to say that inj duty has NOTHING to do with engine RPM for such scenario?
Since injector duty reads how much time the injector is held open, and that's that.
Postby slighty_sykotic » Tue Sep 12, 2006 1:45 pm
yup, so higher injector duty cycle = more fuel. Simple.
At same speed, compare duty cycles (well, must be same fuel pressure aswell), and that will tell you how much fuel is being used.
--Sykotic
slighty_sykotic
Postby neon_spork » Tue Sep 12, 2006 1:47 pm
Wouldn't it just depend at which rpm the engine operated most efficiently?
As someone has mentioned, both cases should require the same power output, so it will come down to the design of the engine, ie which rmp it can most efficiently make that power at.
neon_spork
Postby strx7 » Tue Sep 12, 2006 1:49 pm
the injector duration is directly related to how much fuel it injects right?
that and the engine RPM will give you a number, which you can relate to YOUR OWN configuration. in regards to comparing it to someone elses set up its USELSS but it's fine to compare in your own set up.
Provided you know how your injection system is configured ie: 1 squirt per engine rpm, or 1 quirt every cam shaft rotation (laymans terms of course)
you can deduce a 'value' for comparison purposes.
Postby Stealer Of Souls » Tue Sep 12, 2006 2:19 pm
strx7 wrote:the injector duration is directly related to how much fuel it injects right?
This makes good sense. If you can measure your Duty Cycle (DC) for your car you can figure out for yourself what will use the least gas. DC is a "complex signal", by this I mean that it can tell you engine load, air consumption and all sorts of other little things.
So yeah. More higher DC = more gas used.
'86 AE85.5 Levin
Stealer Of Souls
Users browsing this forum: Google [Bot] and 3 guests
