Lets just say its some assembly required at the moment...
Hopefully I can stay committed to it in the long haul and make something choice out of it.
No pics at the moment, but theres not really alot to see
liftback wrote:After a long spell away from Toyota's, i've been bitten with the bug again and have just purchased a Ke20 rolling body that will be the base of a project.
Loudtoy wrote:liftback wrote:After a long spell away from Toyota's, i've been bitten with the bug again and have just purchased a Ke20 rolling body that will be the base of a project.
Wher'd you manage to scam a 20 from?? Hope it's a good shell for you to work with at least. Get it running 1st then at least you will be able to cruise around to get a feel for what it may turn into if you put the gze/silvertop combination.
Altho if you change cars as often as your old man you'l have sold this and have something else before i wear my boots out - my boots are starting to leak
flygt4 wrote:early gze bottom ends are the strongest of the lot , they have the largest rods and lowest compression pistons.
