should be interesting
Postby deaf_rattle » Fri Oct 20, 2006 8:04 am
http://www.trademe.co.nz/Trade-Me-Motor ... 206221.htm
see the comment about the v6 turbo?
what motor would he use for that? the 3l camry motor?
Postby Adamal » Fri Oct 20, 2006 8:32 am
The 3 litre Avalon motor hes putting in his SW :P
Postby Snoozin » Fri Oct 20, 2006 8:42 am
Adamal wrote:The 3 litre Avalon motor hes putting in his SW :P
Windom motor methinks. 3VZ-FE.
Snoozin
Postby Gonad » Fri Oct 20, 2006 9:38 am
Snoozin is correct I believe.
1 X GT-FOUR RC
1 X ST191 Caldina
Gonad
Postby Adamal » Fri Oct 20, 2006 9:40 am
Ahhh whoops, yea, its from a Windom.
Postby RedGoesFaster » Fri Oct 20, 2006 12:13 pm
I guess if you wanted to know anything about it you'd find the info here:
http://www.clubaw.co.nz/forum/viewforum.php?f=32
RedGoesFaster
Postby Dirtbag » Fri Oct 20, 2006 8:12 pm
Tradme wrote: ye so wat wud be the difference?? posted by: rainbow16 (25 ) 12:41 pm, Fri 20 Oct
Wel itz big3R- so ye wud hav mor lag and lotz mor potentel for powr. U cn mak 1 thouzant horsepwr wid this tbo. 35+ PSI >& it wil flow enuf to suply it to n e ??) car engn at n e RPM. 7:17 pm, Fri 20 Oct
hahah what a ripper
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby Alex B » Fri Oct 20, 2006 8:15 pm
hes on here by the name of mr_monkey. And i think its a 3vz-fe hes putting in. The write up is on club aw.
Postby mr_monkey » Fri Oct 20, 2006 8:27 pm
Yeah thats mine. Any questions you are welcome to ask :-).
-Nathan
<------------you can see a cool pic of it there :):)
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby Mr Revhead » Fri Oct 20, 2006 9:46 pm
does it do sweet jumps?
Postby cr1mnl » Fri Oct 20, 2006 9:59 pm
so does the 3s gearbox bolt up to the 3vz? i need a manual box with lsd to bolt up to my fwd 3sgte and mr2 are overpriced and still have to be modified to fit. if a 3vz manual (if they exist) or even the 2.5l (4vz?) camry box will fit i'll try find one of them.
www.ology.co.nz
cr1mnl
Postby mr_monkey » Fri Oct 20, 2006 10:07 pm
cr1mnl wrote:so does the 3s gearbox bolt up to the 3vz? i need a manual box with lsd to bolt up to my fwd 3sgte and mr2 are overpriced and still have to be modified to fit. if a 3vz manual (if they exist) or even the 2.5l (4vz?) camry box will fit i'll try find one of them.
You'll probably never find a manual camry box here in nz :-)
Yeah, bolts to the mr2 gearbox perfectly 8)
-Nathan
mr_monkey
