C52 part needed - please help!
Postby cogent » Tue Oct 24, 2006 6:28 pm
ok
so on the aw11 c52 gear selector shaft, theres a pin which holds one of the linkage arms to the shaft.
I require a new one of these, and after speaking with revhead at parts, the best course of action was to check on toyspeed if anyone has one, rather than ordering a $5 part from japan and waiting 3 weeks for it.
Especially considering this part is holding up my 20v swap into my AW11, which is my daily driver!
The part is highlighted below, which also shows its relation to the rest of the linkage assembly.
It is part 33527D on that diagram.
If anyone has this part spare, it would be greatly appreciated if you could let me know, aswell as whether or not you would sell it to me :D
cogent
Postby *84vvt* » Wed Oct 25, 2006 5:25 pm
Im might have one at work
failing that will bring a die nut over to night and see if we can sort your old one out
*84vvt*
