Stopping a car from being moved
Postby ollieboy » Mon Feb 19, 2007 1:04 pm
I have an old wreck of a car in the backyard that I don't want towed away but someone is coming to tow it away. I won't be here when they come so I want to make sure the car stays exactly where it is. Any ideas on what I can do to the car to stop it being moved? Don't mind if I render the car permanently useless so all your ideas would be appreciated
ollieboy
Postby 2LTR Rona » Mon Feb 19, 2007 1:06 pm
if RWD then take the diff out & store it somewhere else..not everyone has a spare diff in there boot
2002 Altezza, 1974 KE25
2LTR Rona
Postby evil_si » Mon Feb 19, 2007 1:23 pm
get some steel rims and weld bits of flat bar to them, basically making them square, then refit with lock nuts :D
evil_si
Postby no_8wire » Mon Feb 19, 2007 1:26 pm
Or simply take off rims and put on blocks...and then put lock nuts on the threads... :wink:
no_8wire
Postby postfach » Mon Feb 19, 2007 1:35 pm
could remove the hubs, even just 2 on diagonally opposite corners should make it pretty damn hard to move.
also, if you don't mind me asking, if it's in your backyard why is someone towing it without your consent?
postfach
Postby Leon » Mon Feb 19, 2007 1:37 pm
Concrete it to the ground.
Postby ollieboy » Mon Feb 19, 2007 1:41 pm
Cheers for the ideas guys
postfach wrote:also, if you don't mind me asking, if it's in your backyard why is someone towing it without your consent?
It's a long story but it involves weird country folk who want what they can't get and by any means.
ollieboy
Postby sergei » Mon Feb 19, 2007 1:42 pm
Get some premixed concrete, get some heavy steel angle (4m), dig 4 holes under the cars hubs, drill 2 holes in the steel 1m length angles (depends on your stud pattern but if it is 4x100 drill 2 holes 100mm apart at the one side of the angle so it will bolt on to the hub. bolt on (weld on the hub would be better idea) the steel angles so they act as the 4 stands half in the ground (car will have to be jacked to certain height or it canbe left to sit on it's belly - not good in rust terms). poor concrete in the holes so when it sets the angles would become a part of concrete.
Postby postfach » Mon Feb 19, 2007 1:50 pm
i think that has to be the best idea yet :lol: would love to see the look on their faces when they saw that
postfach
Postby bbq1988 » Mon Feb 19, 2007 1:54 pm
move it to somewhere else?
or put fluro army cargo nets on it ;) im sure they wont see it :D
Baked, Not Fried.
bbq1988
Postby Malcolm » Mon Feb 19, 2007 2:10 pm
park another 15 wrecks around it and weld them all together :)
Postby Silent Knight » Mon Feb 19, 2007 2:16 pm
Dip the car in Cyanide then park it so that all 4 wheels is sitting on a mine each. That way when they try to move it...
Silent Knight
Postby Alex B » Mon Feb 19, 2007 2:34 pm
Meh just electrify the car.
Postby XERO » Mon Feb 19, 2007 2:48 pm
remote control can, witha swarm of killer bee's inside? :?
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby thegreatestben » Mon Feb 19, 2007 3:20 pm
Mongrel mob it: Shotgun and a trip wire
thegreatestben
Postby Jebus » Mon Feb 19, 2007 4:24 pm
Do a 20V conversion on it.
Jebus
Postby Snoozin » Mon Feb 19, 2007 4:28 pm
Jebus wrote:Do a 20V conversion on it.
OH NO YOU DIDN'T!!!!!!!!!! :lol:
I like the idea of welding it to many other cars, that'd be worth at least a couple of laughs.
Snoozin
Postby Pies » Mon Feb 19, 2007 4:36 pm
ROFL!
Current Rides:
Pies
Postby DJ » Mon Feb 19, 2007 4:42 pm
Actual LOL. :lol:
DJ
Postby Dell'Orto » Mon Feb 19, 2007 5:07 pm
Malcolm wrote:park another 15 wrecks around it and weld them all together :)
Best idea EVER
Users browsing this forum: No registered users and 47 guests
