Cheap Wideband O2 ?
Cheap Wideband O2 ?
Postby johntramp » Thu Feb 22, 2007 1:07 am
Hey. Apparently some VW's come with Bosch LSU4 wide band O2 sensors. Is there any chance that they also have a controller with them or would that be internal to the ECU? Is there anywhere I can find a WBO2 controller cheaper than the LC-1's at around $250 ??
johntramp
Postby Akane » Thu Feb 22, 2007 3:45 pm
Postby JamesM » Thu Feb 22, 2007 4:33 pm
i believe ur using megasquirt,,, either of these work with MS.. you can try inovate motorsports LC1 also.. (what i use) about 300$ for controller and sensor
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
