Where in auckland to buy carbon fibre fabric & approx pr
Postby Ae92typeX » Fri Mar 02, 2007 6:24 am
as in title, just the fabric required. Im looking for ~ half a meter square for something.
Is just an idea at the moment, so if to much $$ I wont bother.
Ae92typeX
Re: Where in auckland to buy carbon fibre fabric & appro
Postby Toymad » Fri Mar 02, 2007 9:16 am
Ae92typeX wrote:as in title, just the fabric required. Im looking for ~ half a meter square for something.
Try www.nzfibreglass.co.nz - they do all sorts, as shown on their website under products then reinforcing.
Toymad
Postby Ae92typeX » Fri Mar 02, 2007 9:28 am
Mint, thank you.
Ae92typeX
Postby Malcolm » Fri Mar 02, 2007 11:54 am
you could talk to High Modulus in Albany, they're the main importer of carbon fibre in New Zealand. They do cash sales although I don't know if they have a minimum order size. They would probably expect you to have fair idea of what you want, because in case you weren't aware CF comes in a variety of weave types and weights
Postby Akane » Fri Mar 02, 2007 12:29 pm
There used to be a guy on trademe who does (something like) 1.5m x 1.25m for $44, I got a roll off him.
Now he no longer around, only racepro sells them for twice the price ($88) and with elss fabric (1mx1.2m approx I think).
Postby Ae92typeX » Fri Mar 02, 2007 11:09 pm
Yeah, was aware of weights thanks.
intending for more of a decorative cover on something on the mini, just a bit different.
Will visit one of the above once regos paid...on all three cars...
Ae92typeX
Postby Caveman » Sun Mar 04, 2007 6:01 pm
Im a noob when it comes to carbon fibre work. Is it similar to glass fibre where you lay the mat and soak it in resin? What sort of resin do you use? epoxy? Cheers
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Akane » Sun Mar 04, 2007 7:39 pm
I thought it was straight forward - Epoxy Resin and just lay it on top
came out really crap, but nevertheless it was an experience.
Postby Malcolm » Sun Mar 04, 2007 10:25 pm
yeah the techniques are the same for most FRP products, eg carbon, glass, aramid(kevlar) etc. Wet lay ups with carbon are a bit gay, but you can get a pretty good finish from it if you're careful (experience helps!). Me and my girlfriend did a repair on the carbon plenum for the fsae car by just doing a wet lay up on it, came out pretty sweet (didn't survive too long though, damaged in shipping on way back from Aus)
Most people use epoxy resin with carbon, but you don't have to. The easiest method to ensure good wetting out is to soak the cloth in resin first, usually by putting a piece of plastic sheet on a bench, lay the cloth onto it, then pour resin on and spread it around with a spatula (plastic bog applicators are good), then pick up the cloth and apply it. Don't do too many layers at once if you're a noob because you may struggle to get them all properly wetted out with no air bubbles between them
Postby Caveman » Mon Mar 05, 2007 9:06 am
Sweet thanks ive got all the tools from fibre glass like the roller for bubbles, just need some resin 8)
AW11 Track Toy
Caveman
Postby Akane » Mon Mar 05, 2007 11:58 am
Glue Guru at wairau is where I went for resin, real helpful guys down there, taught me all the basics while I bought stuff from there.
Postby Malcolm » Tue Mar 06, 2007 8:58 pm
I'd recommend our sponsor, Adhesive Technologies in Henderson, I'm fairly sure they'll sell to the public and they're good bastards
