Price check...
Price check...
Postby Brick » Fri Mar 02, 2007 2:03 pm
I got a mazda capella im wrecking, but i dont no what the engine/gearbox/loom and ecu is worth.
Its a 2l DOHC injected engine and got a 5sp manual g/box.
everything works, and has done 150,000kms.
Any one go any idea what it would all be worth?
Thanks
Brick
I know Kung Fu
Postby bbq1988 » Fri Mar 02, 2007 2:11 pm
Three beans fiddy
Baked, Not Fried.
bbq1988
Postby Snoozin » Fri Mar 02, 2007 2:49 pm
Jeez shouldn't you be asking this on the Capella forums, christ. :P
Maybe 250 - 350 I suppose, I don't see the ECU etc. helping a lot as it'd likely be the sort of thing purchased as a replacement engine for one thats not worth fixing?
Heres what I suspect is much the same thing on TM:
http://www.trademe.co.nz/Trade-Me-Motor ... 762923.htm
Snoozin
Postby fuel » Fri Mar 02, 2007 9:07 pm
Those engines are quite bad at blowing head gaskets or cracking/warping heads. Bottom ends aren't so strong either.
They are probably worth a bit to the right person, it's all about finding the right buyer. If you can hold out for a while ask for $400, otherwise if you want a quick sale ask for $200.
Phone up a bunch of wreckers and see how much they would want for the same engine, then charge roughly 2/3 of that.
I sold a mitsi 4G63 DOHC N/A for $350 and that was a quick sale. If I held out a while I probably could have got $600, purely because theres a high demand for them.
LOUD NOISES!!!
fuel
Postby strx7 » Fri Mar 02, 2007 10:27 pm
those engines are currently selling thru the dismantlers for $400-500.
so $300 should see you sell it. as for the gearbox, ask $150-175 and you'll sell it.
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
