6ft 4" and i fit fine. the stock steering wheel came out of a bus parts bin i think. It's far too big to of been in a sports car. So as mentioned, an upgrade in that dept makes things nicer.
as everyone else says... Rust.
Anyone that lists their AW11 as 'rust free' is a liar or just hasn't looked hard enough.
Boot floor - under carpet
Frunk - Under carpet
Wiper sill - foliage collects and blocks water from draining (its hard to check aswell unless prospective sellers will let you rip out the interior of their car :\ (both sides)
Behind the windscreen - up top on the roof
Boot - pull up the rubber seal
rear arches - around wheel
rear arches - under side skirt
rear arches - rear most boot side (water pools into it and go no where, someones poured anti rust into mine :S)
Hinges? - I see red oxide paint around mine so someones done some work there at some stage
The list goes on, still want one?
If you find one that has rust in all those places your very unlucky though
It's usually one place or the other.
Facelift is way cooler then pre and the brakes ( stock ) took a punishing from me at puke recently and never gave me any grief.
http://www.trademe.co.nz/Trade-Me-Motor ... 732078.htm
it's pre face but alot of work has been put into it already.
Hope this helps
