anyone played with one of these yet?
are they as good as they sound? im thinking of getting one.
also did anyone find a solution to the retarding of the timing by the factory ecu problem (even with the earlier safc & safc2)
RH9 wrote:Work well on 25t Skylines, seen a car go from 160kws to 210kws just by tuning the fuel via the Neo.
Good unit
frost wrote:if it is then i was thinking don't run it and the factory ECU wont know its running different then factory fuel maps. and in turn not retard the timing as is world do when it senses an off the norm reading. does this sound correct or does the ecu just go into limp mode if the oxy sensor is not plugged in?
