is this true
is this true
Postby groupagt4 » Wed May 02, 2007 3:39 pm
a ct26 bigger than a ct20b?
http://www.trademe.co.nz/a.asp?id=97570915#qna
read the questions
groupagt4
Postby sergei » Wed May 02, 2007 3:48 pm
As in wheel sizes? Don't think so.
Re: is this true
Postby anthonym » Wed May 02, 2007 3:58 pm
groupagt4 wrote:a ct26 bigger than a ct20b?
read the questions
Well I read your question and found it somewhat obtuse :?. I'd say the external dimensions are very similar. If you mean flow capacity, the CT20b is bigger. If you mean wheel size the CT20b compressor is bigger, but the turbine is smaller.
anthonym
Postby RomanV » Wed May 02, 2007 4:05 pm
AnthonyM.... Now that's a name that I havent heard in a while. :o
Postby Bling » Wed May 02, 2007 5:30 pm
Next time use a more meaningful thread title.... such as
"Is a CT26 bigger than a CT20B?"
oh and as above, how about describing what size difference you want to know, talk about lazy
:lol:
Postby groupagt4 » Wed May 02, 2007 6:55 pm
wel if you read the questions you would be able to see that bigger means more flow or more capable of making a efficient 18 psi.basically the guy is saying a ct26 is beter than a ct20b
groupagt4
Postby Adydas » Wed May 02, 2007 6:57 pm
i dont read " flows more " from the question i saw, id jump to assume your talking wheel size like most ppl seem to think when you talk about a mesurement
Adydas
Postby RedMist » Wed May 02, 2007 6:58 pm
groupagt4 wrote:wel if you read the questions you would be able to see that bigger means more flow or more capable of making a efficient 18 psi.basically the guy is saying a ct26 is beter than a ct20b
Sorry to say... but what bloody questions? What guy?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Adydas » Wed May 02, 2007 7:02 pm
Comon redmist, you know.. The guy!!
Adydas
Postby thaphatty » Wed May 02, 2007 7:12 pm
buritto? yeah, I know him.....
thaphatty
Postby soopachargen » Wed May 02, 2007 7:35 pm
damn that p is nasty sh!t...
When in doubt, down and out.
soopachargen
Postby AJz » Wed May 02, 2007 8:15 pm
hey likes to talk about himself in 3rd person, come on, we are all guilty of it at some point.
As AnthonyM said, compressor is alot bigger, from memory the CT20B is noticably bigger in physical size than a CT26.
I had vtax :(
AJz
Postby groupagt4 » Wed May 02, 2007 8:39 pm
ok i feel stupid :oops: added the trademe link now
groupagt4
Postby fivebob » Wed May 02, 2007 9:34 pm
The CT20 is bit smaller then the CT26 az the Ct26 has power range 350-395hp running at 18psi max which is capable if engine can handle and other mods like ecu and fuel pump is changed.
lol, even in modified form the CT26 isn't capable of that sort of power, the exhaust turbine can't flow enough (which is why some people try clipping it). Best examples I've seen put out about 290HP atw in 2wd form, even allowing for excessive drive train loss of 10%, thats still only around 320HP at the crank
The CT20B is a much better turbo and in stock form is good for about 310HP atw, so using the same excessive drivetrain losses that makes it around 355HP at the crank.
In short CT20B > CT26 :twisted:
Users browsing this forum: No registered users and 30 guests
