This can't be good... (warning 56k)
Postby sigma » Fri Jul 20, 2007 5:19 pm
Put a catch can in my car a couple of weeks ago so decided to check it yesterday....
Previously clear lines had gone a funny colour...
Overflowing (oops) with something resembling oil...
Milkshake anyone?
And under the oil filler cap... hmmm.
So does this look like the classic symptoms of a BHG/cracked head to you guys? I mean thats what I'm thinking looking at the catch can, but the filler cap looks pretty clean and so does the coolant. And today the return line on the catch can has some foamy cr*p in it. Comments please!
1985 MR2 AW11 20v
sigma
Postby Distrb » Fri Jul 20, 2007 5:33 pm
Re: contents of catch can.
I'd expect that to be the case... hot air contains alot of moisture, so when the air cools and heads out the breather filter, you're left with oil and water in the can... which looks like that when it mixes....
how long has it been since you emptied it? looks like a while!
Distrb
Regular Poster
Postby pjay » Fri Jul 20, 2007 5:34 pm
8O dude.. someone shat in your engine!
pjay
Postby Mr Revhead » Fri Jul 20, 2007 5:55 pm
how is that hooked up? vented at all?
bigports are well known for lots of oil in the head.
looks like its spitting oil into the can which is mixing with all the water.
i was empying mine of 500ml of water a month on average.
Postby sigma » Fri Jul 20, 2007 6:00 pm
Sealed can, line from rocker breather to can to plenum.
I knew the oil was gonna be off-colour and I shouldn't put it back in the engine after getting caught in the can, but I wasn't expecting this thats for sure.
1985 MR2 AW11 20v
sigma
Postby sigma » Fri Jul 20, 2007 6:04 pm
Maybe 2 weeks at the most?
1985 MR2 AW11 20v
sigma
Postby Mr Revhead » Fri Jul 20, 2007 6:07 pm
the way you have that set up itll suck oil/fumes from the head and dump the heavy stuff in that can.
theres quite a bit of water vapour in an engine, thats mixing with the oil.
the result is that gunk.
Postby sigma » Fri Jul 20, 2007 6:13 pm
Mr Revhead wrote:the way you have that set up itll suck oil/fumes from the head and dump the heavy stuff in that can.
That was the idea behind doing it like that, as AFAIK the bluetop doesn't have a PCV valve(?) and i figured ventilation was a good thing.
So you reckon I should block up the return on the plenum and just have the line hanging down to the ground?
1985 MR2 AW11 20v
sigma
Postby rollaholic » Fri Jul 20, 2007 6:44 pm
whats the oil in the sump like? doesnt look like a headgasket problem from those pics, its easy enough for a garage to test though if you have any doubts.
Postby varix » Fri Jul 20, 2007 9:07 pm
Lol
varix
Postby TrouserFxGt » Fri Jul 20, 2007 9:12 pm
do lots of short trips?
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby RS13 » Sat Jul 21, 2007 1:44 am
I had heaps of that milky gunk in and around the breather tube on that black AE92, but non under the cam covers.. I did a lot of short trips, its' just moisture mixing with oil, no biggie. I went for a decent thrash over to Akaroa, it pretty much disappeared aside from traces in the pipe.
RS13
Postby Mr Revhead » Sat Jul 21, 2007 10:00 am
from what i can see you have it going:
cam cover
sealed can
manifold
some of the oil and vapours will be trapped in that can
any water vapour will condense in there as that can will be cool, and will remain relativly cool. so oil + water = that mess you have there.
it will also be sucking vapours and any over flow from that tank straight back into the engine intake.
how thick is that fluid? it looks mostly oil. which brings up several possibilitys
1: typical bigport oil collection in the head under high revs
2: ring blowby pressurising crank case and head, blowing oil out the hose
3: something else iv forgotten :P
Postby Truenotch » Thu Jul 26, 2007 9:46 pm
Looks like a mixture of fumes from blowby condensing and the oil from the breather blowing into the can.
I think that the majority of 16v 4age smoke is made from oil going though the breather and being re-burnt :P .... well that and valve stems.
What does the car run like? How many K's and has it been re-built lately?
Truenotch
Postby sigma » Thu Jul 26, 2007 11:56 pm
200,000 kms, bottom end was rebuilt a bit over 10,000kms ago, but the head wasn't. Smokes quite a lot with the catch can on, have since blocked up the return on the plenum and vented the can to air. Didn't cure the smoking problem.
Side note, the engine likes to foul number one cylinders spark plug after being revved hard. I'm starting to think the new rings haven't bedded in properly, as its making a bit much smoke to just be the stem seals. Other than that the car seems to run ok... when its not just firing on 3 cylinders.
1985 MR2 AW11 20v
sigma
Postby Truenotch » Fri Jul 27, 2007 3:10 pm
So the whole bottom end was re-built, with new rings? Does sound a lot like glazed bores mixed with some extra oil from leaky valve stems... Maybe.
Did you do the run in on it?
Truenotch
Postby Dell'Orto » Fri Jul 27, 2007 6:46 pm
Yeah sounds alot like glazed bores if it was a fresh rebuild. Easy fix though :D
Postby slighty_sykotic » Fri Jul 27, 2007 7:52 pm
Mmm, Boost wrote:Yeah sounds alot like glazed bores if it was a fresh rebuild. Easy fix though :D
sand into bores? :twisted:
How would you cure it?
slighty_sykotic
Postby Dell'Orto » Fri Jul 27, 2007 9:48 pm
Well thats an option, though usually getting the block honed is the better way :lol:
You can buy a glaze breaker hone from Powerbuilt, which looks to be just a drill powered hone.
Postby Truenotch » Sun Jul 29, 2007 10:12 pm
That gritty Jif stuff / valve lapping slurry + glazed bores + running engine = mint
:lol: Try it, I dare yah! 8)
Truenotch
