lock picker required (auckland)
Postby supradave » Fri Sep 07, 2007 6:03 pm
i picked up a supra rolling body, but no keys at all.. if theyres anyone in the auckland region whos keen to give it a shot. That would be great. Im in glen innes (and no its not stolen)
ive got a new lock set for it but i cant get the ignition lock out without turning it to ACC.
021 2111408
sooner the better as im gunna keep trying till i get it.
Dave
ADMIN EDIT: oversized image removed - see forum rules for acceptable image sizes
supradave
Postby postfach » Fri Sep 07, 2007 7:38 pm
is it possible to get it off easier if the whole barrel is taken off? (or is that what you're trying to do?) you should be able to undo a couple of bolts with no heads (forget what they're called) with a hammer and a punch and take the whole barrel off the steering column. As for removing the keyed part, thieves get them off with minimal tools....
postfach
Postby supradave » Fri Sep 07, 2007 7:53 pm
nah thats a bit much.
i got it off in the end tho.. wasnt to hard once i found a drill. i mean its a little damaged but seems only visual damage works fine so far :)
prolly shouldnt have bothered with this post but i really didnt think id get it.
Thanks for your response tho
supradave
Postby Mr.Phreak » Fri Sep 07, 2007 7:53 pm
postfach wrote:forget what they're called
Shear bolts
Mr.Phreak
