Ae111 Suerstrut coilovers?
Postby trueno_20v » Sat Sep 29, 2007 7:10 pm
Hey just brought a 1997 Trueno bzr superstrut, does anyone know of any coilovers for it? I know TRD and Tein make them but who else? cheers
ADMIN EDIT: signature too large
trueno_20v
Postby BZR4AGE » Sat Sep 29, 2007 7:39 pm
Beside Tein and TRD
KYB super street special is only damper adjust, and only available if you import from Japan
GAB sports used to make them but discontinued
Arogasta in Japan also custom make them, but don't expect to get a set unless you have $5000 spare.
Koni used to make them, but not sure if they still do
Thats all the choices you have.
You may want to considered just converting superstrut back to McPerhsion (spelling, sorry). then you have a lot more choices, like Cusco, C-One, buddyclub, etc etc. most major brands in japan makes them for McPerhsion.
BZR4AGE
Postby trueno_20v » Sat Sep 29, 2007 8:55 pm
Is there much involved with converting? (last option)
trueno_20v
Postby Grrrrrrr! » Sat Sep 29, 2007 9:31 pm
Short answer yes, its a bit of work.
long answer depends how good a job you want to do of it.
for least effort/potentially unsafe job of it you need the cross-member, struts (complete with brakes etc) and linkages off a non-SS ABS equipped ae111.
Problems: your brake bias will be screwed, as will your ABS calibration due to the change of brake calipers and rotors.
To do a better job you need to find a way to fit the superstrut rotors and calipers to the non-SS suspension.
This will required certing.
Grrrrrrr!
Postby BZR4AGE » Sat Sep 29, 2007 9:47 pm
why don't you try to get a set of TRD damper adjust suspension with TRD low spring from revhead. He got some really great deals - which will cost less than the Tein coilovers. That will make the car look good enough. AND it is more suitable for NZ roads, especially if you are in Auckland.
currently with my GAB coilovers, although they are more comfortable than the TRD ones i Used to have, but they are still a bit bumpy on the smallest bumps. Personally if i were to do my suspension again, i would just go for damper adjust.
BZR4AGE
Postby TRD_ZERO » Sun Sep 30, 2007 10:28 am
How often to you plan on adjusting the coilovers? I had to have a set as i though it would be cool to adjust it up and down changing the height and all. YOu get over it, basically to set it once to the desired height and thats it. so cheaper option would be to get the damper adjustable with lowered springs. My 2c
TRD_ZERO
Postby Scotty » Sun Sep 30, 2007 12:58 pm
TRD_ZERO wrote:How often to you plan on adjusting the coilovers? I had to have a set as i though it would be cool to adjust it up and down changing the height and all. YOu get over it, basically to set it once to the desired height and thats it. so cheaper option would be to get the damper adjustable with lowered springs. My 2c
Well every time you adjust them if its a road car you would have to get them recertified
Scotty
Postby Dell'Orto » Sun Sep 30, 2007 4:49 pm
Not quite, the cert is set for the height + or - 5% (or is it 5mm? something anyway)
Postby TRD_ZERO » Sun Sep 30, 2007 5:42 pm
Mine are trd adjustable coilovers i dont have a cert for them anyway....its not needed.
TRD_ZERO
Postby AE82 FXGT » Sun Sep 30, 2007 8:38 pm
I'm pretty sure that all coilovers need a cert
AE82 FXGT
Postby TRD_ZERO » Mon Oct 01, 2007 7:23 pm
NO they dont, do a search on the forum and it will explain everything.
TRD_ZERO
Postby trueno_20v » Mon Oct 01, 2007 7:48 pm
TRD_ZERO wrote:NO they dont, do a search on the forum and it will explain everything.
Are you running trd coilovers in an ae111 superstrut? what are they like?
trueno_20v
Postby TRD_ZERO » Tue Oct 02, 2007 7:02 pm
Yeah the are for super strut. I wouldnt reccomend them for the road (the ones i have) they are as hard as hell you feel every bump. The rear wheel likes to come off the ground every now and again when pulling into akward driveways. It really depends on how fussy you are when it comes to comfort. I must say the handling is amazing i have never driven anything like it so i just love it. So the handling out weighs the stiffness.
I think there might be two different types of adjustable coilovers that trd make for them unfortunatly i have the circuit stuff. A set went on trademe awhile back for a few hundred but this stuff isnt cheap new.
TRD_ZERO
Postby AE-0000 » Tue Oct 02, 2007 10:43 pm
I did have TRD damper adjust suspension with TRD spring on my AE111 SS as well and like "TRD_ZERO" say before, they are very hard even with the lowest damper setting, but i would said they are about 40% more harder compare to stock just to give you a rough idea. The ride height on them was just right as well, I had like a 3 fingers gap between the guard and tyres with 15 inch rims on mine.
AE-0000
Postby 78ke30 » Wed Oct 10, 2007 12:19 pm
http://www.tweakit.net/shop/product_info.php?currency=NZD&products_id=5437&detail=true
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Key Features:
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
Previously owned: 1980 1275 gt mini clubman, 1979 mini clubman, 1980 ford escort, 1978 toyota corolla ke30
Current AE111 levin BZR
78ke30
Postby BZR4AGE » Wed Oct 10, 2007 12:40 pm
78ke30...are you sure they got a set for superstrut? more than likley they are only for the non-superstrut model.
I remember asking once a while ago and they said none was available for the supersturt. It would be awesome if they are now! :wink:
BZR4AGE
Postby Fortyone.co.nz » Wed Oct 10, 2007 4:08 pm
There's no K-Sport option for Superstrut!
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
