The 'Manu' Button - What does it do?
Postby suprakid » Tue Oct 09, 2007 8:39 pm
I've had 2 Toyota's.
1988 Corona
1986 Supra
They've both got a manu button, i've always wondered what it does...?
It stands for Manual that i'm aware of, but yea tell me!
suprakid
Postby Silent Knight » Tue Oct 09, 2007 9:18 pm
If both of them were auto it's probably to lock up the TC so that it changes gear later and you can make use of more of the revs...
Silent Knight
Postby AE86less » Tue Oct 09, 2007 9:37 pm
My 86 MR2 has one, i think it means that when you shift up through low and 2nd it will stick in those gears instead of adjusting the revs.
The Power button is what lets the engine go up to the red.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby matt dunn » Tue Oct 09, 2007 10:26 pm
Manual mode for auto transmission,
if your cruising at 50k, and the auto is in 3rd or higher and you plant to about 3/4 throttle, it should not drop down a gear,
so you can use a lot of throttle without using a lot of revs.
Postby gmacrae » Wed Oct 10, 2007 8:45 am
what ^he^ said - its just like the 'hold' button in a nissan - holds whatever gear the shifter is in, and probably locks the torque converter up in some cars
gmacrae
Postby SkylineObsession » Wed Oct 10, 2007 9:00 am
What sort of Nissans? The hold button in my Skyline is basically a 'gentle' mode. I.e. it changes gears way sooner and smoother (no matter how much you plant it) and doesn't drop below second gear, ever.
With power switched on it revs higher, changes gears sharper and just goes like a rocket generally. ;)
SkylineObsession
Postby Pelo » Wed Oct 10, 2007 1:02 pm
It is the same as the snow button on NZ new cars.
If you press MANU and put the car in L2 it will take off from a standstill in 2nd gear to stop wheelspin in slippery conditions.
Also good for burnouts...
Pelo
Postby fx gt » Wed Oct 10, 2007 1:25 pm
SkylineObsession wrote:What sort of Nissans? The hold button in my Skyline is basically a 'gentle' mode. I.e. it changes gears way sooner and smoother (no matter how much you plant it) and doesn't drop below second gear, ever.
manual is where its at :P
fx gt
Postby gmacrae » Wed Oct 10, 2007 1:47 pm
These descriptions are cracking me up. The MANU/HOLD button is to force the car to use whatever gear the selector is in. So if you're doing 50k's up a hill, hit "hold/manu" with the selector in 3rd and plant the boot, it should hold 3rd gear instead of grabbing second. So it "Hold"s the gear selected or gives you true "manu"al gear control - makes sense huh :)
However I'd say most cars have a failsafe. So if you've got the MANU/HOLD button in and the selector is in overdrive, and you pull up to some lights, it wont keep holding 4th to pull away from stopped or the trans wouldnt last too long, i's not got anything to do with any kinda snow/grip control, its just so you dont screw the trans for using the button when you shouldnt.
gmacrae
Postby Silent Knight » Wed Oct 10, 2007 2:00 pm
Dude, that's exactly what I said except I used one line instead of 2 paragraphs. :lol:
Silent Knight
Postby gmacrae » Wed Oct 10, 2007 2:06 pm
Silent Knight wrote:Dude, that's exactly what I said except I used one line instead of 2 paragraphs. :lol:
You weren't trying to explain it to ^those two^ :lol:
gmacrae
Postby Mike- » Wed Oct 10, 2007 5:41 pm
my laurel will try and take off from the lights in 4th if the hold button is on, i get a bit lazy driving that thing
Mike-
Postby Pelo » Wed Oct 10, 2007 9:02 pm
That is what I read from an old Toyota technical bulletin when I worked at Toyota...
Pelo
Postby frost » Wed Oct 10, 2007 10:48 pm
i just tried it on the way back from dinner, it still down shifts if i plant foot, no matter if you cruising at 50 or leave it in 2 or every thing in between. and if you 3/4 throttle of course its gona stay in the same gear, so im not quite sure about the manu button anymore maybe it doesn't do anything part from filling a hole in the center console,
Postby suprakid » Thu Oct 11, 2007 7:59 am
I think i've got it....
On the way home from school yesterday, I droped it from 'D' into 'L2' and it went straight from 4th (the gear I was in) to 2nd...then i pushed the manu button and tried it again, this time it went from 4th to 3rd for a brief second then into 2....
It just does it so it's not so hard on the gearbox i think.
suprakid
Users browsing this forum: No registered users and 36 guests
