Help with BZ
Help with BZ
Postby BROCKZILA » Fri Oct 12, 2007 8:20 pm
What are the differences with the BZ models T, G etc TRG? What are the options for them what is the best one to get. Is there much difference between corolla and carib? Any year or model better or worse than another?
Thanks
BROCKZILA
Postby Dell'Orto » Fri Oct 12, 2007 8:27 pm
BZ-T's are wagons, BZ-G/Rs are coupes. Caribs have different rear windows/lights/b pillar backwards to Corollas.
Postby BROCKZILA » Fri Oct 12, 2007 8:31 pm
Thanks for that :) what is this http://www.trademe.co.nz/Trade-Me-Motor ... key=590788 hence my confusion
BROCKZILA
Postby BROCKZILA » Fri Oct 12, 2007 8:32 pm
What is the sprinter model?
BROCKZILA
Postby mycoolcar » Fri Oct 12, 2007 8:50 pm
BROCKZILA wrote:Thanks for that :) what is this http://www.trademe.co.nz/Trade-Me-Motor ... key=590788 hence my confusion
That is just a car dealer who is confused as to what the car actually is.
Hell it says "Transmission Details: 5 Speed Manual" and then on the next line it says "6 SPEED".
Its 6 speed manual 4age. Carib BZ Touring (BZ-T).
mycoolcar
Postby Mr Revhead » Fri Oct 12, 2007 9:31 pm
Dell'Orto wrote:BZ-T's are wagons, BZ-G/Rs are coupes. Caribs have different rear windows/lights/b pillar backwards to Corollas.
yeah, basiclly panel wise the carib is completly different.
mechanicals the same though
Postby Andy » Sat Oct 13, 2007 8:05 am
By BZ-TRG, I think the dealer meant BZ-Touring.
Andy
Postby TrouserFxGt » Sat Oct 13, 2007 6:49 pm
For what it's worth caribs are quite a bit smaller than the corollas. If that matters.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby Mr Revhead » Sat Oct 13, 2007 8:46 pm
in what way?
they are on the same platform etc.
Postby TrouserFxGt » Sun Oct 14, 2007 1:34 pm
Mr Revhead wrote:in what way?
From my comparisons when I owned a 96 bz-t corolla and a 98 bz carib at the same time.
Boot width, length and height are smaller in carib. Ceiling hight is lower in carib. Cabin width is narrower in carib. Less rear leg room in carib.
H J Simpson.
TrouserFxGt
Postby Mr Revhead » Sun Oct 14, 2007 2:45 pm
ok ones an ae101 and the other a 111
but they have the same track and wheel base.
bloody weird if they are that different.
how much different are we talking? its prob just the different trims and seats.
i think i'll have a closer look!
Postby TrouserFxGt » Sun Oct 14, 2007 9:45 pm
Most of the difference is in the more 'shapely' 101 body. Very evident when you look in the boot.
H J Simpson.
TrouserFxGt
Postby BROCKZILA » Mon Oct 15, 2007 12:46 pm
Any faults that I should look for?
BROCKZILA
Postby Mr Revhead » Mon Oct 15, 2007 12:49 pm
not really
just usual things like correct maintanence has been done etc
Postby mycoolcar » Mon Oct 15, 2007 1:17 pm
And the typical blacktop things like big end bearings.
mycoolcar
Postby TrouserFxGt » Mon Oct 15, 2007 8:19 pm
BROCKZILA wrote:Any faults that I should look for?
Rear shocks and worn synchros. About it really.
H J Simpson.
TrouserFxGt
