by Prymal » Wed Feb 20, 2008 10:10 pm
if you want uprated 205 suspension, frank aka the longest name in history AKA NZNEWgroupAGT4 ( one of the other guys here who has one of the 4 NZ new group A's ) has a set of TRD adjustables up fro grabs with springs to suit i believe, he just upgraded recently to coil overs
Whiteline rear Swaybar is the best mod ever youc an do to a St205 IMHO , best bang for bucks
Exhausts , wel HKS do a very very good quality cat back setup , Aussie exhaists in Brisbane OZ do a Excellent front dump pipe , and midpipe/cat ..
This is what i have under my car - all stainless , all 3 inch ..
Cost a pretty penny but worth every cenbt for guaranteed quality workmanship with less chance of cheap replica Dumps cracking ..
Dunno much about boost controllers , as mine doesnt really need one atm - 18 PSI is your boost cut , tweak it to around there however you like or enjoy the factory ecu allowing that boost on those cold cold NZ nights
Apexi make a sweet bolt in St205 pod fiilter/intake pipe cmbno that eliminates the rubber one fron the factory and the big airbox , everything bolts up , quality once again is assured , and its worth it if you can afford it
Greenline , Repco ( yay my work ) and redline performance can supply these bits
Thats My 2 cents ..
personally i wouldnt bother with fancy boost controllers - Just get an ECU that can do the lot for you , like the powerFC ( discontinued ) or the wolf V500 Plug and play ECU
